up-pipe help
Old Dec 29, 2005 | 10:29 AM
Fhantom-rex's Avatar
up-pipe help
smoke seems to be coming from my newly installed up-pipe and i cant find out where the problem is tell me if this has happened to ne1 else
Old Dec 29, 2005 | 10:33 AM
subie OCD's Avatar
Car Info: 04 STi
Did you use any lube/wd-40? I used wd-40 to help loosen the bolts and when the car was first started after install, the wd-40 smoked for a bit.
Old Dec 29, 2005 | 10:40 AM
i did use wd40 to loosen the bolts last night and sprayed it all over the place, but that was last night
Old Dec 29, 2005 | 10:57 AM
subie OCD's Avatar
Car Info: 04 STi
Its most likely the wd-40(especially if you sprayed it everywhere), just drive it around lightly until it burns off.
Old Dec 29, 2005 | 11:04 AM
yeah it probably was that because when it was burnin off n smokin it had a weird smell to it like not even gas smell so thanx
Old Dec 29, 2005 | 11:35 AM
scustoms's Avatar
new gaskets burn in and smoke a bit too.
Old Jan 12, 2006 | 06:27 PM
AFter installation there was some fluttering noise only when i really get on the throttle or up into the 4,000 rpm range. It doesnt sounds like a leak, but does anyone know if that is normal or what for a full TBE with an up-pipe. Im guessing it is probably jus the turbo
vsick
May 16, 2011 02:26 PM
fliped wrx
SoCal Classifieds
Jun 8, 2007 10:52 PM
gdbimpreza
Mar 3, 2005 12:12 PM
gdbimpreza
Jan 20, 2005 05:25 PM
Siyah
Apr 20, 2003 06:12 PM
