Overheating problems
Old Nov 25, 2002 | 07:51 AM
korpse's Avatar
Car Info: Subaru
I've been running without the turbo heatshield for a few weeks and I haven't had any heat issues. A friend of mine has been running for a few months without the heatshield and he hasn't either.
I planned on putting my heatshield back on, but I haven't noticed any problems so I'm in no rush to replace it. Is anyone else running without a heatshield???
Old Nov 25, 2002 | 09:28 AM
Slvrblt's Avatar
yea, heat soak is bad mmkay
that might be the problem, but I could have sworn those working with an aftermarket turbo don't have a heat shield on- may want to check on that
speed safely
Brian
Old Nov 25, 2002 | 09:58 AM
stealth-wrx's Avatar
try draining it again and filling it back up. then wait for the thermostat to open and fill some more.
Old Nov 25, 2002 | 12:23 PM
bamfwrx's Avatar
Car Info: 02 WRX
I'm with stealth-wrx
there must be some air traped in the system some were in the system. try to find a high point and loosen the hose/fitting and see if any air escapes.
don't do that with the cooling system pressurized hot I don't want to hear about you being burned in the eye by coolant
Old Nov 25, 2002 | 04:08 PM
En3D's Avatar
It's not the heatshield. Sure the heatshield may help a very very very little with heatsoak.
The overheating is something with the radiator flushing. I noticed when I flushed mine it took a few "tipoff" to actually fill the radiator.
JFxConcept
Jul 29, 2009 09:17 PM
-WickedRex-
Dec 18, 2006 06:57 PM
grex767
May 27, 2006 10:37 AM
