Overheating at idle
Old Mar 12, 2005 | 04:49 AM
wizurd's Avatar
Car Info: WRX 02 Silver wagon
Overheating at idle
Im overheating at an idle at lights.......... as soon as i step on it drops down to normal........ is this a thermastat misreading and i need to replace?? water pump going?? need some advice./
thanks
Old Mar 13, 2005 | 09:29 AM
Uncle Scotty's Avatar
....are your fans running???
Sounds to me like your fans aren't coming on....check the fuse(s)....try turning on the AC.....the fans should run with the AC on...
Old Mar 13, 2005 | 10:55 PM
SuperHawk's Avatar
Car Info: 2006 WRB Wagon Ltd.
Hi,
You need to top off your coolant! I have a 02 WRX and was having this same problem a few months ago and topping off the coolant made the problem go away.
Super
Old Mar 14, 2005 | 10:46 AM
meilers's Avatar
How long have you been allowing this to happen? If it happened more than just a few times, go get a compression test -- aluminum blocks and heads rarely survive repeated overheats. Did you heat up enough to get a dash light?
wizurd
Mar 15, 2005 11:30 AM
Dead Pig
Apr 26, 2003 10:37 PM
trhoppe
Nov 26, 2002 07:32 AM
