open downpipe
Old Jun 26, 2004 | 01:29 PM
yamatodamashii's Avatar
Car Info: s2
open downpipe
i tried seaching but nothing found....has anyone done this??a friend of mine has done it to his turbo hatch, and sounds like a damn semi commin! but is it good or bad to run a open downpipe?(without a cat back xhaust). much info would be great
Old Jun 27, 2004 | 01:04 AM
Daredevil's Avatar
i've ran my car around the block a few time with no cats and no catback
sounds real mean but b/c there is no back preasure you lose a lot of torque
not worth it
Old Jun 27, 2004 | 10:03 AM
dorrington's Avatar
not a lot of torque?...im not too sure of that. Turbocharged cars don't need any backpressure at all. If there is no backpressure past the downpipe, it keeps the exhaust gases further upstream moving faster. It all kindof creates a vacuum that helps utilize the turbo to its fullest extent. I think anyone will tell you that backpressure is bad, and reducing it will increase both horsepower and torque. check this web page at vishnu: http://www.vishnutuning.com/exhaust101.htm
I think the largest concern would be having your downpipe open right underneath the car, and the possiblity of fumes entering the interior. I'm not sure if it actually is a hazard, but I would at least have some pipe that directed the gases out to the side. Further, I'm not sure it would help. If you had an aftermarket dp and the stock exhaust, then, yes, I think you would probably see some improvement.
Old Jun 27, 2004 | 12:26 PM
MeshmeZ's Avatar
Car Info: 2007 silver STI
backpressure is only your friend if you have an n/a motor. though now that i think about it you might loose some power down low before the turbo starts creating boost. then again with no backpressure you might get rid of some turbo lag... i agree that if you were to do this, and plan on running it like that for a prolonged amount of time you should get something to route the exhaust out the side of the car. the last thing you want is exhaust fumes making their way into the car.
I definately wouldnt do this in california. thats a REALLY easy way to get fined. =)
Old Jun 27, 2004 | 08:11 PM
Ben's Avatar
Ben
Car Info: Stock....so far
yeah, i just installed a turbo xs dp and a helix uppipe, and decided to run with no catback for a few minutes. Damn did it sound beefy. Woke the neighbors up, but no cops..yet. it's sweet.
Old Jun 28, 2004 | 03:16 AM
Imprezer's Avatar
Admin v2.0
Car Info: 02 Black Legacy GT
I agree, turbocharged cars do not need any back pressure. Running open downpipe will definetely increase your top end.
Old Jun 28, 2004 | 11:18 AM
WindingRoad's Avatar
Car Info: 2004 White GDB
the bottom of the car could get a little toasted. i'm guessing that it would shoot bigger flames under the car without the catback
Old Jun 28, 2004 | 03:17 PM
RoadSpike's Avatar
Definitely, friend of mine with a totally catless system says he's shooting fireballs out of a borla hush. lol
ERZperformance
Jul 26, 2012 02:00 PM
GripItUp
Dec 25, 2009 10:41 AM
lazybummm
Oct 3, 2005 11:46 AM
Mastermind
13
Aug 3, 2004 12:26 PM
Puguglies
May 2, 2004 08:14 PM
