old WRX questions...
Old Nov 26, 2002 | 04:31 PM
John #555's Avatar
Car Info: 02 WRX
well, i did the search but nothing... (thanks to v.2 i-club )
1. is it ok to put in 5qts of oil instead of 4.8qts? I think i smell oil burning from under hood but no leak..?
2. STi hood scoop really better for cooling I/C or just cosmetic?
thanks.
Old Nov 26, 2002 | 04:40 PM
stealth-wrx's Avatar
you should be fine with 5 quarts. maybe you spilled some oil and its burning off or you didnt tighten you oil filter all the way.
Old Nov 26, 2002 | 04:47 PM
John #555's Avatar
Car Info: 02 WRX
i didnt think it'd be big deal. my dealer INSIST that i put 4.8... i hope youre right. i'll double check the filter, fumoto valve, etc.
has anyone seen any kind of temp reading with STi scoop vs stock?
Old Nov 26, 2002 | 05:50 PM
John #555's Avatar
Car Info: 02 WRX
thanks!
Old Nov 26, 2002 | 05:52 PM
.2 cant do that much. its not like your pressure is going to go through the roof
Old Nov 26, 2002 | 07:03 PM
Slvrblt's Avatar
I just put it in till it says good
measuring is for girls
speed safely
Brian
Old Nov 26, 2002 | 07:47 PM
Weasel 555's Avatar
Car Info: WRBlue WRX modded!!!
Lightbulb
if you can get the STi Underscoop with splitter too to go with the STi scoop ...
Andy...
Old Nov 26, 2002 | 10:50 PM
John #555's Avatar
Car Info: 02 WRX
you mean like this one?
well, not quite the splitter...
I had my dealer do the oil change twice so far and both times they gave me back .2qt
Old Nov 27, 2002 | 10:16 AM
John #555's Avatar
Car Info: 02 WRX
Originally posted by inski21
Maybe I gotta short stick!?
i hope not.
another q:
how does dry sump work? is it applicable to flat engine layout?
Old Nov 27, 2002 | 10:19 AM
short stick. lol
Old Nov 27, 2002 | 08:42 PM
ScoobyBoy's Avatar
5 quarts should be fine.
the sti scoop - well some people say it does give gains, some say it doesnt. i personally believe an air splitter will be better.
Old Nov 27, 2002 | 09:59 PM
John #555's Avatar
Car Info: 02 WRX
Thanks for all your input. The reason i ask about 5qt is because I can smell oil burning from under hood, but i didnt see any leaks or spills. i thought maybe i put too much oil and somehow caused the smell. i've been putting in 5qts whenever i do the oil change.
maybe i should invest in a catch can just in case... ?
