Oil temperature normal?
Old Jul 7, 2004 | 01:49 PM
jasno999's Avatar
Car Info: Blaze yellow WRX 2002
What is a normal Oil temperature?
What is a normal oil temperature reading on a WRX? 210? 190? What is high?
Old Jul 7, 2004 | 11:35 PM
Imprezer's Avatar
Admin v2.0
Car Info: 02 Black Legacy GT
I don't know oil temp in F, but on my uber modded WRX, the oil temp is always about 10-15' hotter than water temp in C. And my water temp is usually ~ 85-90 degrees C. Hope this helps, a little bit.
Old Jul 8, 2004 | 01:51 AM
RoadSpike's Avatar
well considering what imprezer said
that would mean the ratio is around 95-105C on oil temp or approximately 200 - 220 F
Old Jul 10, 2004 | 09:34 PM
Alizarin's Avatar
I just installed my Defi gauges today. My oil temp sensor is in the rear gallery (under the intercooler). Driving home on the interstate @ around 65mph it was about 200F, and going across the bridge at 115 it went up to around 220, but not higher (about 4 minutes worth of 100+ driving).
What is considered "high" is of interest to me, since I still need to set the warning value.
Old Jul 10, 2004 | 10:03 PM
RoadSpike's Avatar
Considering its probably your water you should be worried about. I'd think around 240-250 you should start to worry a lil
Guillermo
Feb 18, 2013 05:45 PM
ratcoon
24
Oct 29, 2006 02:18 PM
robert1217
Apr 14, 2003 10:59 AM
PsiStar
Mar 18, 2003 04:50 AM
msg101
Mar 14, 2003 08:23 PM
