oil smell
Old Jan 15, 2007 | 09:22 PM
evanc's Avatar
Car Info: 02 WRX Wagon
Question oil smell
So I've noticed that when I have the blower on to defrost the windows I get a pretty strong oil smell when idling. When I'm moving it isn't a problem. Where could the oil smell be coming from? It's even bad when I have the windows open and I'm at idle.
I'm totally new to the Subaru world so thanks for putting up with the silly questions.
Thanks,
Evan
Old Jan 21, 2007 | 02:58 AM
WRX>Civic's Avatar
Car Info: '03 PSM Wingless WRX
mods?
Old Jan 21, 2007 | 09:05 PM
evanc's Avatar
Oil Smell
Originally Posted by WRX>Civic
mods?
No mods at all. I was reading somewhere else that the intake for the blower is at the base of the windshield? I can see vents of some sort on my car, but can't confirm if that is where the air is being pulled in from.
I'm still baffeled.
Old Jan 22, 2007 | 09:26 AM
wagonrex's Avatar
Check your hoses.. make sure they are all properly connected. I had that smell before from one of the lines to the fuel filter. the 02 and 03 don't have those adapter things that secure those hoses.
Old Jan 22, 2007 | 12:41 PM
Egan's Avatar
Check for an oil leak. The 02 & 03 WRX's had a problem with the crank seal and/or oil pump seals failing. The tell tale sign was a slight drip of oil running down the oil filter or oil at the bottom of the crank cover.
Old Jan 22, 2007 | 02:52 PM
evanc's Avatar
Ahh, so the oil leak that I see off the front of the block could be the common crank seal or the oil pump seal eh. I sprayed down my motor to get a better look and I still haven't located the leak, but that would make sense that the smell would be sucked into the cabin on the fresh air setting. I need to get a manual. Which manual would be the best to get? Haynes? Chiltons?
Thanks for the responses. I've got a place to start now!
Munashi
May 6, 2004 04:42 AM
EtchyLives
Mar 14, 2004 10:36 AM
namitherussian
Feb 5, 2004 11:06 AM
redoo2000
Jan 19, 2004 08:36 PM
jbhebert
May 19, 2003 05:21 PM
