Exhaust info
Old Jan 15, 2007 | 08:14 AM
colorado_sport's Avatar
Car Info: 05 wrx @ stage 2
Arrow Exhaust info
So after searching and pondering,I am so to upgarde to a TurboXS exhaust system it goes from the turbo all the way back.My question is if i do it my self is it going to be hard to get the down pipe off from the turbo or no.Also does anyone know if this is a good exhaust system.
Old Jan 15, 2007 | 04:19 PM
WRX>Civic's Avatar
Car Info: '03 PSM Wingless WRX
Great choice in the TBE, as for the installing, its pretty easy as long as you have the right tools. For example, a good socket for the bolts and to make it easier WD40 the bolts beforehand. But i did it without so i believe you'll be okay. Is pretty straight forward is only 9 bolts total that are holding up the downpipe.
Old Jan 15, 2007 | 08:20 PM
MO REX's Avatar
Car Info: 02 PSM WRX
+1
Are you going with the RFL?
Old Jan 16, 2007 | 01:38 PM
Wrxzero557's Avatar
Car Info: 04RA
its pretty easy to put it on
Old Jan 17, 2007 | 09:26 AM
will i have any problems without the use of an acess port if im running the stock intake.
Old Jan 19, 2007 | 02:54 PM
ezombie's Avatar
Car Info: 2005 OBP WRX
I had mine on for about a month or so before I got it tuned and it was fine. Just dont drive it super hard......but over all the TurboXS turbo back is a good choice.
Old Jan 21, 2007 | 02:52 AM
WRX>Civic's Avatar
I believe running the TBE without tune is fine. Its only if you change the uppipe, thats what really needs the tune. The reason? i dunno hahaha. But for my 03 I have the TBE on my car for 3-4 month without a tune and its doing fine. But with the tune you'll get more out of the mod ^.^
Old Jan 21, 2007 | 01:13 PM
[W5]IntoTheWRX's Avatar
Car Info: wrx
same with wrx>civic, i ran my turbo back for couple months without tune. but i got the cobb AP after because i didnt want to take any chances with killing my engine. just as long as you dont drive like a maniac without your tune i believe it wont hurt much. but getting a tune with your tbe will unleash full power of the mod.
Old Jan 21, 2007 | 02:48 PM
pj21086's Avatar
I wouldnt take any chances running it without at least some sort of engine management. you will raise your boost levels by using a turboback and the stock ecu isnt set up for that.
Old Jan 22, 2007 | 03:20 PM
Cool thanks for all the help guys.
FLYSTI05
Jul 14, 2008 05:10 PM
DMC07WRX
May 1, 2008 09:29 PM
Bagin,DVS
May 12, 2007 12:57 PM
Island Style
Sep 21, 2006 11:31 AM
rally_wrx
Sep 19, 2006 04:31 AM
