oil problem
Old Jan 30, 2003 | 10:47 PM
deeseeone's Avatar
Car Info: Black 02 Wagon
Unhappy oil problem
i'm losing about 1 quart of oil in about 1500 miles... i just checked my oil today and i'm about 1 quart low... i dont really push the car hard i just drive a lot...my car has about 12000 mile on it.. does anyone have this problem???
dave
Old Jan 31, 2003 | 08:19 AM
RallySubie's Avatar
Yep,
I have had this problem also. Took it two three different dealers and they said it is normal. However i don't believe them. Within the next week i am going to do a compression check just to see where i stand. I am going to be changing the spark plugs so i figure i might as well do it then.
Some say that if you used synthetic in the early miles of the car (~6000), the rings may not have sitted properly. I started using synthetic around that time.
I have about 20,000 miles on my car.
Old Jan 31, 2003 | 08:52 AM
deeseeone's Avatar
oil
kool.. i was gonna do one too... just to see also.. let me know what happends...do u have a lot of blow by???
dave
Old Jan 31, 2003 | 10:12 AM
RallySubie's Avatar
I have not noticed any smoke coming from the exhaust. However it is hard to tell why you are driving. If i am it is not enough that i would see by just looking back through my mirrors.
I have checked when i start the car in the morning. No smoking at all.
Old Jan 31, 2003 | 09:19 PM
bamfwrx's Avatar
Car Info: 02 WRX
This is exactaly the poor service that I have come to expect from subie dealers
Yeah loosing oil is normal if you don't have a drian plug in the oil pan
I not dissing on all subie dealers just all the dealers that I have had dealings with.
Please report back with your findings You could check and see how much oil has made it's way to the intercooler, some is normal very little thought
I switched to synthetic at 2700 miles with no problems what weight and brand oil are you running? I have hear somthing about redline oils dissapearing from subie engines
Old Jan 31, 2003 | 09:36 PM
RallySubie's Avatar
I am using Mobil 1 5-30 synthetic. Does anybody know what the typical compression numbers are?
Old Jan 31, 2003 | 09:54 PM
bamfwrx's Avatar
Car Info: 02 WRX
hey that's the same oil I run
the subaru manual says to warm uo the engine then with the throttle open and at 350 rpm you should get between 138-166psi
121psi being minimun spec and no more than 7psi between cylinders.
I have not done a compression test on a subie but I have done many never caring weather the engine was warm or if the throttle was open mainly you look for the number of times the needle bounces and the diff between cyls
does that make any sense?
Robert
Old Feb 4, 2003 | 05:55 PM
RallySubie's Avatar
Is it a quart from the low to the max? I just realized that i have never used a full quart to bring it up all the way again.
Maybe one quarter of a quart. If it is a full quart to go from the low mark to the max mark, why am i able to top off with less than a quart?
I am still going to do a compression check this thursday.
Old Feb 4, 2003 | 06:10 PM
bamfwrx's Avatar
Car Info: 02 WRX
not to be ****
But is there a stain?
Do you smell oil after you park?
Old Feb 4, 2003 | 07:01 PM
RallySubie's Avatar
Nope,
No stains, no strange smells, and no obvious smoking here.
deeseeone,
Does it take you a full quart to top off from the low mark to the max mark?
Old Feb 4, 2003 | 08:17 PM
bamfwrx's Avatar
Car Info: 02 WRX
I don't gave any of my car books or my car here so I'm not 100% but I would think that 1QT is right for low to high.
have you had someone ride be hide you? to see when and if your car smokes?
Old Feb 4, 2003 | 08:35 PM
bamfwrx's Avatar
Car Info: 02 WRX
Originally posted by 03impreza2.5rs
most vehicles are considered normal to use 1qt of oil for every 1000 miles.usage increases with freeway driving.its when u start seeing a qt every 500 miles is when u should worry
WHAT?
show me the tsb's
wo what ?
