Oil pressure behavior
Old Oct 17, 2003 | 10:51 PM
Imprezer's Avatar
Admin v2.0
Car Info: 02 Black Legacy GT
At what pressure, is the oil pressure considered too low?
What should oil pressure be at idle?
At what pressure, is the oil pressure is considered too high?
Does oil pressure stay steady at WOT or does it fluctuate?
Anything else should one know about a very heavily modded flat four?
- Alex
Old Oct 18, 2003 | 04:18 AM
Chibby Goku's Avatar
Car Info: Vakamon WRX
I don't know what's normal, but my car idles at about 30psi and sometimes goes as low as 20psi before it prematurely shuts off.
I haven't reached further than 100psi yet. I'm still breaking in my motor.
I'm also interested in what is normal.
Old Oct 19, 2003 | 10:00 PM
madrex's Avatar
Car Info: 03 Rex: HKS, Injen, Apexi, Perrin, Rota
Question
i dont mean to hijack the thread here, but i'm in need of some info, and you (Akiata) seem like you might have some answers. I have an oil temp probe mounted on top of the block under the intercooler, but i am adding a pressure gauge and don't know where to put the probe? it sounds like you have both mounted at the filter, is there some reason that is a better place? what is the best way to tap into the oil there. sandwich adaptor? thanks, you can PM me if thats easier for you. later, Ben
Old Oct 20, 2003 | 10:27 PM
RallySubie's Avatar
I am using the greddy gauges and mine also read in kg/cm2.
I've been getting about 1.5kg/m2 at idle and about 4kg/cm2 while driving. This is with the car fully warmed up.
According to the subaru manual it should be 1kg/m2 or 14psi or more at 800rpm and 3kg/cm2 or more at 5000rpm.
Old Oct 21, 2003 | 01:06 PM
Kean's Avatar
Car Info: 03 WRX / 08 Forester
Re: Oil pressure behavior
- Alex
My readings are as follows:
Engine Cold:
Cruising: ~100 PSI
Idle: ~100 PSI (drops to 90 after a minute and gradually lowers as it warms up)
Engine Fully Warm:
Cruising: settles down to around 70 - 80 PSI
Idle: settles down to around 20 - 30 PSI
As far as too low or too high? .......I would say anything that is a few PSI below 20 or significantly above 100 should be investigated.
My pressure usually stays constant @ WOT. Any fluctuations that may occur are gradual but will stay in the ranges I've described.
Hope this helps. ........btw, these readings are on a stock '03 WRX with an Omori gauge.
- Kean
Subadubaru
Feb 6, 2013 02:20 PM
06ezSTI
Apr 22, 2008 08:00 PM
suby_dude
Feb 12, 2008 01:28 PM
JackHCChen
Nov 12, 2005 09:50 PM
turbo_j
Mar 16, 2003 02:49 PM
