Oil Catch Tank
Old Jan 1, 2004 | 06:22 PM
WickedWRX's Avatar
Car Info: Silver 2002 WRX
Oli Catch Tank
Can someone explain to me what advantages there are to an oil catch can? What exactly does it do? Is it worth putting on my nearly stock car?
Old Jan 1, 2004 | 06:28 PM
ish's Avatar
ish
Re: Oli Catch Tank
it catches oil in a can
Old Jan 1, 2004 | 06:29 PM
WickedWRX's Avatar
Well i established that much, but what purpose does it serve?
Old Jan 1, 2004 | 06:52 PM
the blow by from the crank case goes back into the intake but this catches it b4 it goes back it helps out with emissions
i would do a sway bar first b4 that
Old Jan 1, 2004 | 09:19 PM
The reason you would want to catch the oil being blown through your PCV (positive crankcase ventilation) system is twofold- one, you don't want it going through your compressor; two, you don't want it ingested into the combustion chamber to foul things up. The purpose of PCV is emissions- the little bit of ring blow-by you get causes positive pressure in the crankcase, which causes small amounts of oil and unburned/partially burned fuel to escape in the atmosphere. In order to cut down on that particular source of pollution, the air circulating through the crankcase is drawn through the intake to be bunred witht he rest of the fuel. It's cleaner, but not so good for your engine. It's not harmful, just reduces efficiency. By catching it in a can, you keep your engine a little healthier.
Old Jan 2, 2004 | 07:04 AM
WickedWRX's Avatar
OK I get it. Thank you
Old Jan 2, 2004 | 12:55 PM
GotBoost?'s Avatar
Car Info: 2003 PSM STi
here is a pretty good explanation of what an oil catch can does, and why you would want one....
-Ted
Old Jan 2, 2004 | 03:30 PM
dr3d1zzl3's Avatar
Car Info: 08 sti
a chrome one adds +5 bling points to your total bling score at a show.
(ban suvs hit it on the head with his post)
BlueSti389
Mar 1, 2004 08:47 PM
iNfEk
Jan 14, 2004 11:24 AM
werx_racing
Jan 1, 2004 01:10 PM
werx_racing
Dec 31, 2003 04:55 PM
subarism
Jun 27, 2003 06:57 PM
