oil catch can??? problem???
Old Feb 23, 2004 | 09:18 AM
Vicore_Wrx's Avatar
Car Info: 2003 WRX, blue
Ok, I ahve a perrin catach can and I have assembled the thing and I have a few question for people that know about his stuff. One, how does this thing work, it doesn't ahve a filter or anything in it, how does it trap the crap inside? Two, if you have one you will know what I am talking about, It ahve two pull-locks on the top and the bottom and they don't seem to seal real well. (if I cover all the holes and blow an air hose in one I can hear little leaks coming from them, is his normal? Three, if this is not normal what should I do to them to make a better seal?
Thanks for any help
Old Feb 23, 2004 | 06:52 PM
MO REX's Avatar
Car Info: 02 PSM WRX
There is a good explanation on another thread titled; install greddy oil catch tank. Do a search and type in oil catch can and you will find it (read through some of the other posts and you might find out more about the problem your haveing). From what it says you need to put something like foam or some type of oil condenceing material in the catch can. Good luck.
Old Mar 10, 2004 | 09:37 PM
Vicore_Wrx's Avatar
not really I had a look and it really was not that helpful
Old Mar 10, 2004 | 10:44 PM
I would put some cotton batting in the can. As for the bad seals, you'll just have to find a way to tighten them up.
Old Mar 11, 2004 | 03:51 PM
Vicore_Wrx's Avatar
thanks for the help BAN
Old Mar 11, 2004 | 09:02 PM
MO REX's Avatar
When I did the same search I found allot of info on how an oil catch can works. I guess you didnt look verry hard. In the thread I mentioned there is a link to scoobymods that shows in a drawing how a catch can works and I do beleive that was part of your question (question #1).
SWAT
Jul 30, 2009 04:47 PM
Teriyaaaaki
Hawaii Classifieds
Oct 19, 2007 04:49 AM
Jballs
Mar 25, 2003 09:44 AM
Dave DD
Dec 29, 2002 11:31 AM
scooby5
Dec 4, 2002 12:24 PM
