Oil Catch Can?
Old Jul 22, 2004 | 04:32 PM
RupeDawgPSU's Avatar
Car Info: 2004 San Remo Red WRX w/ Premimu package, Security package, and Short Throw shifter
Oil Catch Can?
I read on a website that turbo-charged engines are prone to residue build-up in the intake tract, and that a oil catch can can help prevent this - resulting in longer turbo life.
My 04 WRX is the first turbo car I have owned, so sorry to sound like the newb that I am, but is there any validity to this at all?
Old Jul 22, 2004 | 05:10 PM
Peaty's Avatar
Not sure about extending turbo life but if the oil makes it to your IC it will make it less efficient:
http://www.scoobymods.com/forums/showthread.php?t=3346
http://www.scoobymods.com/forums/showthread.php?t=2769
Old Jul 24, 2004 | 12:24 PM
BIG GUN's Avatar
Car Info: 2002 WRX SILVER WAGON
Oil Catchcan
I bought a Helix. It looks great! Nice polished stainless, but I cant find a space to install it. Take a look, there isn't much free space.
Old Jul 24, 2004 | 12:37 PM
Peaty -
Is it a regular occurance for oil to get to your IC?
Old Jul 24, 2004 | 12:40 PM
InfamousDX's Avatar
Car Info: '03 WRX Sedan
Peaty... has this since cure your oil in the IC problem? I have a little bit of oil in my metal IC lines, the ones that run parallel across the front of it. I was wondering if this is worth it and can the oil be very detrimental to my motor's health?
Old Jul 24, 2004 | 03:28 PM
Wingless Wonder's Avatar
Keeping the intake charge free of oil contamination is worthwhile because it can make the intake charge more prone to detonation - at least that's my understanding. A small amount of oil vapor may not cause a problem unless your engine is tuned to the ragged edge of detonation. Some engine builders even specify ashless engine oil, again to ward off detonation.
Another benefit of a catch can would be to keep the inside of the intercooler clean and dry, allowing it to pass as much heat as it possibly can to the ambient air.
Old Jul 24, 2004 | 06:31 PM
meilers's Avatar
If an intercooler has been running for 25k miles without an oil catch can, can you flush the inside of it out somehow before adding a catch? Or will just adding the catch can allow the oil to vaporize and be trapped?
Old Jul 24, 2004 | 06:33 PM
meilers's Avatar
Most installs are right behind the right headlight (the light to your right as you face the engine compartment); there's a flat horizontal piece of frame material next to the battery that has a convenient hole drilled in it...
That is, if you have a WRX; the model of car matters! Both of Peaty's links are to Forrester installs, but I've seen a WRX install of the Perrin can on Scoobymods as well.
SWAT
Jul 30, 2009 04:47 PM
Teriyaaaaki
Hawaii Classifieds
Oct 19, 2007 04:49 AM
Jballs
Mar 25, 2003 09:44 AM
Dave DD
Dec 29, 2002 11:31 AM
scooby5
Dec 4, 2002 12:24 PM
