Is this normal
Old Jun 24, 2006 | 05:37 PM
dahawkster's Avatar
Car Info: wrx
Is this normal
I have a 2003 wrx with a up & down pipe and intake and my car spikes to 16 and 17 pounds of boost if i get a set of headers and a catback will i gain more boost and will it be safe
Old Jun 26, 2006 | 09:29 AM
Annapolis Subaru's Avatar
Car Info: Need Parts Now?
Adding exhaust parts should in no way modify boost levels. The only thing that modifies boost is a boost controler, engine management, etc... If your boost is erratically spiking beyond stock levels without you adjusting it, that means that you have a problem. I have heard of certain pipes causing boost spikes so you may want to look in to something different. Which exhaust do you have?
Thanks,
Jackie
Annapolis Suby
443-837-1422
Old Jun 26, 2006 | 09:37 AM
SubyN00by's Avatar
first off, how are you reading boost? second are you the only owner of the car? My car was boosting a bunch, then I found out the previous owner had tuned it.
Chris04WRX
Jun 5, 2003 11:50 PM
traction
May 7, 2003 08:51 PM
msg101
Mar 14, 2003 08:23 PM
killaho
Feb 18, 2003 02:52 PM
