No boost
Old Jul 29, 2005 | 07:59 AM
hoopty's Avatar
Car Info: 02 wrx
No boost
Yesterday while I was driving home I lost almost all of my boost. The turbo will only spool up to about 5 psi not enough to open the blow off valve. Anybody have a problem like this?
Old Jul 29, 2005 | 08:01 AM
soggynoodles's Avatar
what mods do you have on the car now?
Old Jul 31, 2005 | 06:21 PM
hoopty's Avatar
Car Info: 02 wrx
Complete exhaust, bov, intake, alt power pulley.
Old Aug 2, 2005 | 10:41 PM
duffmanaudio's Avatar
Did you find the reason for the lack of boost. I have the same problem.
Old Aug 2, 2005 | 11:19 PM
hoopty's Avatar
Car Info: 02 wrx
Not yet.
Old Aug 3, 2005 | 10:01 PM
PyroManiac's Avatar
From: Are you too one of the few still living the past? Well I can change that! With a simple wicket. Yes, my friend, a wicket. PM for details.
Car Info: No car right now....sob.
Check your exhaust....possible uppipe leak?
Old Aug 3, 2005 | 10:26 PM
WRX Rush's Avatar
Car Info: Stage 4+ Bugeye
Any intake lines missing ? The wastegate Valve missing the pill from the turbo ?
Good luck,
Austin
Old Aug 16, 2005 | 02:58 PM
I fixed it
I finaly figured out what the problem was. it was a bad wastegate control solenoid valve.
if you want to check if this is the same problem your having. disconnect the vac line off the wastgate controler. and take it for a LITE drive around the block with it disconnected. you will be at max boost so take it easy & dont get addicted to the power. if you get max boost the problem is your wastegate control solenoid.
solution buy a boost controler & hook it oh so the factory controler is out of the loop
this was just the problem I had I am not saying thatyour situation will be the same
yzercyber
Aug 12, 2005 03:42 PM
Astacun1
Jun 28, 2003 03:12 PM
mattr762
Apr 18, 2003 09:12 AM
ShokWaveRider
Feb 21, 2003 06:14 AM
XwrxX
Dec 17, 2002 07:14 AM
