need help asap
Old Jan 7, 2003 | 10:34 AM
Rexstang's Avatar
First 12sec WRX in HI
Car Info: 12.93@106.71
Can you post a pic? Also what size vacuum lines are you using? If you are using large vacuum lines it may cause your boost controller to not be able to build pressure. The smaller the vacuum lines the quicker pressure builds. Take a couple good shots of your set up and we'll be able to help out better.
Old Jan 7, 2003 | 03:40 PM
Nolimit's Avatar
Where is my beer?
Car Info: NSX, G35
which factory lines did you use?
there is a restrictor inside the line that goes from the 'T' to the compressor fitting. It shouldn't matter, but it might.
you should buy some vac line and use it for starters. What mbc are you using? Obviously, if you connect it 'backwards', it will not allow you to adjust boost any higher.
CynicalCS84
Jan 25, 2011 09:01 AM
CaliSuby
Dec 13, 2008 07:21 PM
lanz0r
Oct 10, 2008 08:13 AM
slow04wrx
May 2, 2008 03:30 PM
resident smurf
May 30, 2005 08:17 PM
