Need Help!
Old May 9, 2005 | 06:14 PM
686entman's Avatar
Exclamation Need Help!
My subaru has 56,000 miles and my check engine light came on i checked it and the codes came up as ..cylinder 1 and 4 misfire..i reset the codes thinking that i need new spark plugs ..the light didnt come back, on till last weekend..i went and checked it again and the codes read cylinders 1-4 misfire and i think the code was PO171..not sure if you reply to this i can have it for you but the code was tellling me that my engine was running lean..now does anyone have any suggestions that could be causing the lean code to show up??and for the misfires is that most likely spark plugs.distributor cap..coils..??i know im due for a 60,000 tune up but if i can pinpoint whats causing these that would help me thanks
Old May 9, 2005 | 08:33 PM
itwrx's Avatar
Car Info: 03 WRX Blue
What mods if any do you have?
Old May 9, 2005 | 08:47 PM
686entman's Avatar
no mods at all..... bone stock
Old May 9, 2005 | 08:59 PM
Egan's Avatar
It could be your plugs going bad or possibly your coil packs.
The car has a 5/60 powertrain warranty, so you might as well use it before it runs out.
Old May 9, 2005 | 09:07 PM
686entman's Avatar
I don't think i have that warranty
Old May 9, 2005 | 09:35 PM
Egan's Avatar
The WRX standard warranty is 3/36 bumper to bumper and 5/60 powertrain, IIRC.
Old May 9, 2005 | 09:39 PM
686entman's Avatar
so if i take it to subaru they will do everything for me?
Old May 10, 2005 | 04:52 AM
Egan's Avatar
If it is just a maintenance item like plugs, they would charge you. If it is the coilpacks, then they should be covered under the powertrain warranty. Read the warranty manual to be sure.
Old May 10, 2005 | 06:55 AM
meilers's Avatar
Check your air filter and make certain the air box is closing tightly.
unstble
Mar 21, 2008 09:09 AM
resident smurf
May 30, 2005 08:17 PM
Eggman's-STI
Oct 5, 2004 10:43 AM
disque71
Apr 13, 2004 11:27 PM
brucelee
May 28, 2003 09:47 PM
