my rex wont pull after 3k help plz
Old Jan 8, 2006 | 11:38 PM
truWRXtacy's Avatar
Car Info: 2005 WRX
well i am at my 31k miles on my odo now. and i didn't do the 15k service because the guy at the dealer said it wasn't really necesary. What is all in the 30k service? i did my own oil change and changed out the air filter. what else do i need to do?
here is my problem, recently when i have try to pull the car a bit it seems like it wants to go at first and it starts to pull at 3k but at like 3200 it kinda jerks back and slows down, then it starts to sound like a ricer, it sounds loud and mean but it dosent go any faster, atleast not what its suppose to be doing anyways. I checked all my hoses and they're all attached and okay. Could my 30k miles check up be doing this to my car? my car's check engline light flashed 4 times then went off. Does this mean i need my 30k miles check up, since i cant do a cel reader on it due to the fact that the CEL does not stay on. Could it be my clutch slipping? but i havnt really driven it that hard so i dont see why my clutch would slip at 30k. Any advice would be great thanks.
My mods are :
HKS hi power cataback
Vishnu Stage sub-zero ECUtek
Old Jan 9, 2006 | 12:26 AM
the clutch can be shot in 30k it depends on how you drive. but i dont think thats the problem.
the ECU stores teh CEL. get it read anyways it wont hurt.
i could be upipe leak. does it boost at all?
30k i think is the fuel filter also
Old Jan 9, 2006 | 12:27 AM
truWRXtacy's Avatar
Car Info: 2005 WRX
i think it boosts, i can hear the tubo spool but since i dont have a boost gauge i dont really know how many psi its putting out.. and i cant get the CEL check because the light isn't on now, it just flashed 4 times and it turned off.. what is a MAS and where is the fuel filter located at and how hard is it to change it out? also can i check my clutch to see if its worn? or do i have to take stuff apart before i can tell?
Old Jan 9, 2006 | 12:28 AM
Imprezer's Avatar
Admin v2.0
Car Info: 02 Black Legacy GT
Can you go on boost? It could be a leak in your charge system. Check all your intercooler hoses. Might be a hole or the hose slipped of.
Or, it could be your MAS.
Old Jan 9, 2006 | 12:30 AM
truWRXtacy's Avatar
Car Info: 2005 WRX
ya it still boosts.. just dont know how much it boost..
Old Jan 9, 2006 | 12:32 AM
what car do you have
if its an STi never mind its in teh tank
wrx its by the shock tower on the drivers side
Old Jan 9, 2006 | 12:33 AM
MAS mass air flow sensor?
Old Jan 9, 2006 | 12:34 AM
truWRXtacy's Avatar
Car Info: 2005 WRX
its a 05 WRX. So should i try to replace the fuel filter first? the guys at the dealer said they replace engine filter also, do they mean the filter in the intake box?
Old Jan 9, 2006 | 12:35 AM
truWRXtacy's Avatar
Car Info: 2005 WRX
is there anyway to have a professional diagnoise the situation w/o spending a fortune? cause i dont want to replace a bunch of stuff and find out that its not the correct thing that i repalced..
Old Jan 9, 2006 | 12:38 AM
have you tried resetting your ECU?
Old Jan 9, 2006 | 12:43 AM
truWRXtacy's Avatar
Car Info: 2005 WRX
no i have not. i do this by unpluggin the red off the battery for about 5 min and putting it back on again right? will it effect my ECUtek in anyway?
Old Jan 9, 2006 | 12:46 AM
i dont think so but im not 100%. 98% sure
thats teh Engine managment forum sorry hehe
Old Jan 9, 2006 | 12:48 AM
Imprezer's Avatar
Admin v2.0
You should call VISHNU and check with them. How long have you had the their ECU for prior to the problem?
Old Jan 9, 2006 | 12:52 AM
truWRXtacy's Avatar
Car Info: 2005 WRX
i've had the ECU for awhile now, had it since april so i dont think its the ECU problem, it only started happening recently. prob started around 29k miles on the Odomoter, and that was on and off and now that i'm at 31k, its happening more often.. would it be wise to get a boost gauge to measure how much boost i'm putting out?
Old Jan 9, 2006 | 12:56 AM
if you have the money yes
if not you can borrow some ones mechanical for a day. im sure they would let you if you buy them dinner or lunch
