Is my ECU all right?
Old Jun 13, 2003 | 10:01 PM
jimr's Avatar
Car Info: 2002 WRX Sedan
Here is some info I found in MRT's WRX book, but note, this applies to the up-to 2001 Impreza WRX (not US spec), but your color scheme sounds alike.
"The procedure to reset the engine ECU is as follows:
1. With the engine switched off and the gear selector in park (A/T cars) connect both the green and black connectors.
2. Switch ignition on and ensure that the check engine light is illuminated. (If not you have a problem and should seek professional advice.) For A/T cars shift the gear lever **** into neutral and then back to park.
3. Start the engine and then proceed to drive the car for at least one minute keeping road speed above 11km/h.
4. If the engine is not up to operating temperature, stop and warm engine above 2,000 rpm.
5. At this point the check engine light should start to flash the all-clear signal (half second flashes). If the check engine light flashes a sequence other than all clear, there is a fault present in the system, and it should be professionally checked for necessary repairs."
Please be clear, this is from an author in Australia, describing the technique for ECU reset for the previous generation Impreza, but it may apply to the 2002 & later, I don't know.
I would imagine that if your ECU was in trouble, you'd have CEL problems, and weird stuff going on with driveability, and the cooling fan cycling on and off (or maybe never coming on), or the car would be waaaay down on power.
Good luck,
Old Jun 14, 2003 | 09:25 AM
awns729's Avatar
Car Info: want a WRX
http://www.cardomain.com/member_page...=293448&page=4
scroll down to tips and tricks...he tells you how to reset the ecu
Old Jun 14, 2003 | 12:57 PM
misterx's Avatar
Car Info: MY 02 WRB WRX Wagon
The car either had a Unicip or a UTEC. I'd go back to the dealer and *****. I've modified the hell out of my car and wouldn't want to be its next owner. I plan to keep mine for a few years, though.
Modified cars are driven hard. Who knows what the previous owner did to or with the car?
X
Rescuer
Jan 16, 2013 11:18 AM
dub2w
Aug 25, 2004 01:04 PM
soundwave
Apr 27, 2004 11:12 PM
GottaREX
Wanted
Feb 22, 2004 07:13 PM
