My car is stalling! (BOV problems)
Old Nov 17, 2004 | 01:02 AM
wagonrex's Avatar
Okay I went and installed a Blitz SS BOV last night and went for a drive. It was doing good for 20 miles or so and than suddenly it stalls on me... I let the car sit on the side of the road for 2 hrs.. and it starts but once I traveled 1 mile or so the car gave up on me again.. it wants to stall...
Good thing I was by my friends house and I called a tow truck to get it there. Now I suspect it's the BOV that is causing the problem.. since I just found out I shouldn't be running an aftermarket BOV while using an Accessport.
My question is.. what should I do now? should I put the stock BOV part back on and it will solve the problem?
Anybody have the same set up as me.. ?
Any help is appreciated.. thank you..
Old Nov 17, 2004 | 01:04 AM
wagonrex's Avatar
One more think is that it was blowing black smoke.... out of the exhaust.. very light thou....
Old Nov 17, 2004 | 01:36 AM
yamatodamashii's Avatar
Car Info: s2
did u disconnect ur battery while installing the BOV?
Old Nov 17, 2004 | 01:40 AM
AzN121184's Avatar
Car Info: civic
why would u do that?
Old Nov 17, 2004 | 01:42 AM
Imprezer's Avatar
Admin v2.0
Car Info: 02 Black Legacy GT
Make sure you don't have a leak.
E.g. make sure that all the hoses are connected, BOV flange gasgets in place and not broken, blow off valve is not stuck open.
Old Nov 17, 2004 | 05:07 AM
Wingless Wonder's Avatar
Origami posted by wagonrex
Your ECU sent your air/fuel ratio pig rich in an effort to compensate for a lean condition it thinks it sees because of your BOV installation. That's the black smoke you saw. Fix the BOV or put the stock bypass valve back on.
It's more than just 'smoke' - unburned fuel washes lubricating oil off the cylinder walls of your engine, leading to poor piston ring seal and accelerated wear of the rings and cylinder walls.
NOTE: Generally, black smoke indicates a rich mixture condition (unburned raw fuel), white smoke is water vapor (probably condensation or coolant), and bluish smoke indicates burning oil in the engine. You can often smell the difference at the tailpipe, too, if it gets to the point where the smoke is easily visible.
Old Nov 17, 2004 | 07:41 AM
wagonrex's Avatar
How would I fix the bov? There is an adjustment screw on top.. do I have to set that? I heard BOV don't get along with BOV.. is that true? Should I just take it off and sell it?
Old Nov 17, 2004 | 11:10 AM
Car Info: s2
why u ask to disconnect the battery?
1. directions say to do that
2. my experience...when i did disconnect my battery when i was installing the HKS, i didnt realize the cable was still touching the terminal, so techincally i guess it was "still connected" in some sense, ran my car...my revs went up and down, over and over. so i back tracked, made the sure nothing was touching the battery, and reinstalled the HKS and problems were gone
my advice, go back and recheck your work...plus redoing the BOV dont take that long
Old Nov 17, 2004 | 11:51 AM
wagonrex's Avatar
I did disconnect the battery when I was installing it.. I think it's more than just have it rev up and down.. it stalls once I drive it for a block or so now... I think I am running too rich and it is not recirulating like the stock bov
Old Nov 17, 2004 | 03:03 PM
playa7's Avatar
Car Info: JBP 04' WRX
i'm running access port stage 2 with short ram and BOV no problems. try oiling up your BOV.
Old Nov 17, 2004 | 03:19 PM
wagonrex's Avatar
I think I need to tighten up the setting on my BOV. Anybody running the Blitz SS... how far should I tighten the bolt
Old Nov 18, 2004 | 10:44 AM
wagonrex's Avatar
Okay when back to my car last night and found out the BoV was STuck open.. heheh.. stupid me.. that is why it was going psshhh psshh pshhh when I stalled...
Playa7-- are you running a 100% vent to atmosphere?
Old Nov 18, 2004 | 02:53 PM
playa7's Avatar
yes i am....turbo xs rfl...... alot of ppl say that its a POS, but i like it. im thinking of getting a Sard bov now, something different.
Old Nov 18, 2004 | 06:03 PM
wagonrex's Avatar
I like how the blitz sound. pretty cool.. and I got it for a good price..
grex767
May 27, 2006 10:37 AM
itzjohnwayne
Nov 4, 2003 07:55 PM
Mayfield
Oct 4, 2003 08:08 PM
Kuth678
Sep 29, 2003 08:20 PM
