MPA to PSI
Old Apr 2, 2003 | 11:12 AM
VF22WRX's Avatar
Car Info: '02 WRX Sedan
16.5 psi is 1.1379 bar. Go to
http://www.worldwidemetric.com/metcal.htm for a conversion calculator.
Old Apr 2, 2003 | 11:36 AM
VF22WRX's Avatar
ok, so your reading is in MPa (megapascals) right? do you want MPa converted to psi or bar?....or both?
Old Apr 2, 2003 | 11:54 AM
VF22WRX's Avatar
16.5 psi is .114 MPa and 1.14 bars
17.0 psi is .117 MPa and 1.17 bars
17.5 psi is .121 MPa and 1.21 bars
Looks to me that you might be right, the difference between Mpa and Bar is a decimal place.
Old Mar 26, 2013 | 01:13 PM
psiguy's Avatar
MPa to psi Conversion tool
I work in the Steel industry and am often running into this conversion problem , My go to tool is Convert: psi to MPa | Mpa to psi | ksi to MPa | MPa to ksi
hope that helps
Old Mar 26, 2013 | 07:45 PM
Heedz's Avatar
Nobody likes the tuna here
hella necromancing here.
japan7
Jul 19, 2006 12:58 AM
spdkills
May 13, 2003 03:54 PM
wrx137
Dec 16, 2002 08:08 AM
schwarzenegger
Dec 3, 2002 01:33 AM
