Motor is really screwed up
Old Dec 1, 2004 | 04:34 PM
Magish's Avatar
1. Find out what is really wrong... making wierd noises can be a number of things, and you really need to get someone in there and see waht is wrong.
2. Do not take off your bolt-on's and then take it in under warrenty... that is just plain dirty, especally if it is due to your modifications.
-Jeff
Old Dec 1, 2004 | 04:40 PM
nachomc's Avatar
-Jeff
word to your mother.
Old Dec 1, 2004 | 05:27 PM
doughboy's Avatar
Car Info: GDA
-Jeff
ditto on that piece of advice!
Old Dec 1, 2004 | 05:30 PM
bassplayrr's Avatar
+1 on not going back to stock to have it fixed. You ply, you pay. The more people that do what you propose, the more like SOA is to deny warranty work that is authentically needed.
-Chris
Old Dec 2, 2004 | 09:04 AM
mmboost's Avatar
Chances are it wasn't the TXS pipe that was the problem. More likely its the installer who screwed it up. A flex pipe is actually easier to install. It doesn't mean that TXS' is crap. When you install a solid uppipe you have to take special care to torque the bolts of both the uppipe and the downpipe in sequence in a round-robin-ish fashion. Do it properly, it won't leak. You should still do this with a flex pipe, but doing it well is not as critical.
jason
Old Dec 2, 2004 | 10:20 AM
qwk_wrx's Avatar
Car Info: 05' Evo 8
contatct gruppe-s they have SPEC C motors for 4,000, or JDM STI motors for under 2000
Rocky
Old Dec 3, 2004 | 06:17 PM
Lurk's Avatar
You can use it, but why would you want to?!
Old Dec 9, 2004 | 06:31 AM
WRXWagon203's Avatar
Car Info: Sold My Stage 4+ Wa-Goon :(
Dude, what the hell are you smoking.. Putting it back to stock and then going to the dealer. Well now.. I can't really think of the legal term.. slander. Not not slander.. its something though.. but lying to the dealer after stating that... woot for you..
Your post has probably already been read by a rep or a parts person (I know a local dealer whose parts guy searches for posts on forums like these) and then you are going to take your car, put it back to stock and get all up in the dealers face.. God dude, don't make me laugh; yeah its been pulled before but karma will come back and bite you in your *insert exclamatory curse word*-ing ***.
Coilovers have nothing to do with the motor... hence you really shouldn't worry about taking those off if youa re still going to go ahead and do this. Yet maybe they could try to pull some geometric-angle bs on you -- then again you would deserve it for going in and LYING.
What you can do... spend 40 bucks, get a compression tester. Do a compression test.. if you need info/instructions just ask. You can also do an oil change -- see if there is any coolant in your oil or pieces of piston, etc -- this isnt always the case.. sometimes it works.
I'd definitely say compression test the bastard see what comes up. Then go from there.
Are you sure you have hardware damage though? Were you boosting around with no map?
No experience in this question hence the reason I'm asking it. If there was no map on that switch. Wouldn't the stock ecu take over? Thats how my UTEC works... I know that for a fact.
Last thing -- if you are in CT/NY/MA I'd be willing to help you diagnose.
-G
Old Jan 5, 2005 | 10:19 AM
nachomc's Avatar
^^ The word you're looking for is fraud.
Krinkov
Mar 9, 2011 09:00 AM
iLoqin
Aug 29, 2008 11:38 PM
RussB
Jun 11, 2004 04:04 PM
Kevin M
May 24, 2003 11:11 PM
Throwdown54
Feb 24, 2003 04:41 AM
