Motor limit
Old Jun 1, 2004 | 09:08 AM
wrxdaddy's Avatar
Hmmm... low 12 to high 11... definitely you need bigger turbo than stock with or without N2O depending on your setup. I've seen several folks got there but their EJ20 on stock internals did not last. You'd be lucky to go past 10K miles without breaking anything in the process.
Old Jun 1, 2004 | 02:21 PM
wrxdaddy's Avatar
16psi should be fine but will you be happy? You will only start appreciating the power of big turbos when you go over 18psi. which in my opinion your stock block starts losing its reliability
Old Jun 1, 2004 | 03:42 PM
Lurk's Avatar
That's why most people who are serious about making big reliable power, go with a built stroker motor. 2.4L, 2.6L, 2.8L. You might wanna check out http://i-speed.us they'll be able to help you out.
Old Jun 2, 2004 | 06:57 PM
MJU1983's Avatar
Car Info: 06 Armada, 03 WRX, 05 STi(sold), 05 Vette (sold)
The standard block can take a fair amount of abuse. The easiest solution to a new block is simply an EJ257, or JDM 2 liter.
-Mike
Old Jun 4, 2004 | 07:49 PM
MJU1983's Avatar
The block itself is decent. The sleeves are decently thick, although it is still a fully open deck block. That is your last concern when pumping the boost through it. It will fail, when is the question.
-Mike
Old Jun 4, 2004 | 11:39 PM
Wingless Wonder's Avatar
Origami posted by simpwrx02
What do you mean by open deck block?
Open vs closed deck.
Old Jun 5, 2004 | 01:33 PM
awns729's Avatar
Car Info: want a WRX
You have a link for everything don't you? Thanks, that helped.
Old Jun 5, 2004 | 02:49 PM
blue blurr's Avatar
i would think a pe18 or 20 would be alright on the stock engine. i dont know since i dont have a after market turbo but i think at 16-18psi it would last and still be reliable.
Old Jun 5, 2004 | 05:53 PM
MJU1983's Avatar
Depends on tuning. And how agressive you are. It will last for a good deal of time if properly tuned. If not, it can fail on your first WOT pull. Just something to think about.
-Mike
kokuryu1
Nov 3, 2003 10:55 PM
jasno999
22
Mar 13, 2003 10:05 PM
DaveWRX
Jan 26, 2003 08:17 PM
