MBC wrong?
Old Nov 16, 2003 | 12:08 PM
IS300's Avatar
Question MBC wrong?
I have a JoePMBC installed in my car. I have the bottom feed going to the nipple of the turbo and the side feed going to the wastegate. So far so good. However, should I be keeping the stock tubing that comes off the nipple of the turbo since the tubing size is different? I have a 3/16" tube for the MBC and the stock one is a lot shorter......Plus How do i adjust the boost? It took me over like 10 times and I was still hitting fuel cut with the boost gauge
HELLLLLLPPPPP
Old Nov 17, 2003 | 06:04 AM
ride5000's Avatar
Re: MBC wrong?
HELLLLLLPPPPP
i used the supplied tubing that came with the joe p, 3/16ths fuel hose, iirc.
start with the adjustment backed all the way OUT, that is, turn it to the left until it nearly comes out of the threads. that should give you wastegate pressure, ~8psi. if it does NOT, then something is wrong.
hth
ken
Old Nov 19, 2003 | 11:11 AM
qwk_wrx's Avatar
Car Info: 05' Evo 8
you say you have a boost gauge right...what is the boost peaking at on the gauge....you might be running alot of boost without knowing you are....i had my boost guage at the turbo inlet and it only read .5 bar. I then moved the hose from the turbo inlet, to the intake manifold and got alot better readings...that might be your problem, or it might not...just trying to help you out.
FuturistiK_STI
Jun 30, 2011 08:45 AM
NRTmotorsports
Jul 30, 2007 07:53 AM
100
Jan 2, 2003 02:46 PM
betawrx
Dec 31, 2002 10:26 AM
100
Dec 31, 2002 10:00 AM
