MBC not working well, what could be wrong??
Old Jul 14, 2003 | 09:07 AM
Mister 2's Avatar
which way did you turn it?
Old Jul 19, 2003 | 10:55 AM
forcefed's Avatar
I, have the Hallman Pro installed, set at 16psi. I haven't tried any more but it definetly hits 16. I'll turn it up a notch and let you know. Did you unplug the stock solenoid or just plug the hose? I heard if you don't unplug it it will burn-out. Mine is just plugged per the instructions. If it was unplugged would it effect the ECU? Know anything about this?
Old Jul 30, 2007 | 07:53 AM
subydood03's Avatar
Car Info: 2003 WRX
Originally Posted by Bostonscooby
Sometimes MBC come with a light spring that even if you turn the BC up all the way you wont get alot more boost. Then you have to change the spring to a heavier one for more boost.
yup! just installed mine, if you didnt buy the one that comes with a heavier spring then you cant get anymore than 15 lbs. so try the heavier spring, its super easy to change.
BlaineWasHere
Jul 8, 2012 06:53 PM
2point5AWD
Sep 6, 2006 09:38 AM
jpartkings
Hawaii Classifieds
Jun 25, 2005 09:33 PM
spdkills
Jan 6, 2003 06:30 AM
