MBC vs. Stock BC with re-map?
Old Jul 20, 2004 | 09:21 PM
nerrad5's Avatar
Car Info: 02 WRX WRB 4EAT VF34 Kit w/AP
IIRC i read the stock boost parameters can be remapped to get rid of the half boost in 1st and 2nd gears and other things. Is this true and is it more benificial then using an MBC and mapping for the PTFB issue?
Thanks in advance
Old Jul 21, 2004 | 09:43 AM
nerrad5's Avatar
bump
anyone?
Old Jul 21, 2004 | 10:27 AM
RoadSpike's Avatar
Originally Posted by nerrad5
bump
anyone?
The boost issue is sorta more of a load on the engine thing than a issue with electronics. You see there isn't alot of load coming from the first two gears to create enough exhaust pressure for that maximum boost. Thats why you test boost psi in 4th gear beacuase its easier for the turbo to get to its maximum.
All in all i've been told the car doesn't like the MBC as much as it likes the remap. If your looking for gains i guess the remap is the way to go.
Old Jul 21, 2004 | 10:33 AM
thebankman's Avatar
Car Info: subaru
getting a remapped ECU like the ECUtek will work better than a MBC. not only will you have a trained professional remap the boost levels on your car, but basically, instead of just changing the boost on the car the entire engine will be tuned to work at its best.
both options have their risk but MBC has no warranty and is easy to use incorrectly and blow up the engine
Old Jul 21, 2004 | 12:09 PM
2Stroke's Avatar
Car Info: 2003 WRB Wagon
Thanks in advance
Yes, it's true. I get .9 bar in 1st gear with the stock BC and a remapped ECU. Any remap or aftermarket engine management will provide similar boost response.
The stock WRX ECU is not programmed for performance as the first priority. It tries to maximize fuel economy when driven "sensibly" (think EPA city/highway cycle), minimize emissions, and protect the engine from bad gas, overboost, high charge temps, etc. Performance ranks 3rd or 4th for the stock ECU.
A remap makes performance a higher priority than emissions or fuel economy.
If your question is about remapping the ECU, but only changing the fuel maps to work with the boost profile of the MBC, that would be possible, but in reality, nobody does it that way. A remap gives you control over the boost response of the SBC, the fuel maps, ignition maps, and much more. It can respond any way your tuner tells it to. Get a reflash from an experienced tuner or company, and enjoy the power without the worry of the MBC.
Old Jul 21, 2004 | 02:56 PM
nerrad5's Avatar
Thank you very much. SBC with remap it is. sounds better for the long haul with minimal issues.
Darren
Old Jul 21, 2004 | 04:52 PM
awns729's Avatar
Car Info: want a WRX
They pretty much did a great job of explaining it . A remap is definitely the best way to go, espeically if you're planning many future modifications. It's much safer, more reliable and definitely worth the money. Also, as you add modifications, I believe you can get it retuned for a very small cost. Someone have details on that?
Old Jul 21, 2004 | 07:29 PM
2Stroke's Avatar
"Reflashed" can be done at low cost, "retuned" implies dyno time and a tuner's personal attention. A reflash with an off-the-shelf map for the mods you just installed is always a possibility, and you can always plan your mods to match maps you know already exist. (That tip was worth the price of admission)
You''re at the point now where you need to contact the tuners directly for the answers you seek, or at least read their web sites.
Old Jul 23, 2004 | 07:23 PM
nerrad5's Avatar
Talking
Thank you. I will start making phone calls.
FuturistiK_STI
Jun 30, 2011 08:45 AM
carletto
Jul 23, 2005 03:20 PM
eyeballs
Aug 12, 2003 08:20 PM
Pi7467mp
Wanted
May 29, 2003 12:10 PM
