mbc question
Old Feb 27, 2006 | 06:59 PM
stealthrex68's Avatar
Car Info: 02 bugeye with tune by Ed
Question mbc question
What are the negatives and positives to running wit a mbc? good idea? bad? wats the max boost i can run off stock turbo? let me kno wat u guys think
thanks
i was lookin at hallman boost controllers so i was curious...
own 02 wrx wit catback and bov..
Old Feb 28, 2006 | 11:23 AM
lightning_wrx's Avatar
Car Info: 2002 Subaru WRX
good and bad
good- NONE AT ALL-WASTE OF MONEY
Bad-will run lean major engine damage
- boost higher in higer gears. will cause fuel cut and possibly detonation
-can not boost much over stock on turbo because you would be not using the effect of the intercooler- higher engine combustion temp.
JUST SAVE THE MONEY AND PUT IT TOWARDS ENGINE MANAGEMENT
Old Feb 28, 2006 | 01:10 PM
JON MACIAS's Avatar
Troll
Car Info: 2003 WRX / 05 TAHOE
Mnb Is No Good!
Old Mar 2, 2006 | 07:12 PM
huffyrex's Avatar
Car Info: 2003 WRX
i put a hallman mbc on my 03, and yes it does creep in 3-5th, my car is almost all stock except hoses and bov. you shouldnt run much more boost than stock, mine would hesitate in 3-5th if i had it too high. its fun to have but i would save my money if i did it over again.
Old Mar 3, 2006 | 09:23 PM
myweaponwrx's Avatar
Troll
Car Info: 03 BLACK WRX & 05 EVO
mbc Is Not Worth It Man! Will Damage Your Engine If You Don't Know How To Use It
Old Mar 3, 2006 | 09:24 PM
Troll
Thumbs up
Originally Posted by JON MACIAS
Mnb Is No Good!
IT'S TRUE
Old Mar 8, 2006 | 01:04 PM
ride5000's Avatar
thanks
if you know what you're doing they can be very effective.
i've had one on my car for 40k miles.
good:
rock steady boost control
dead simple design
in my case, in cockpit "boost" **** to set desired levels
bad:
in the wrong/inexperienced hands they can kill your engine in a short time
have a "bad rap" as a result
some attention to part throttle full boost must be paid
stock turbo is known good up to 20psi--again IF YOU KNOW WHAT YOU ARE DOING. i ran that way all last winter. when i pulled it off it was in fine shape... ie no troubling amount of shaft play.
i had a LOT of supporting mods to do this. do not assume you can slap an mbc on a stock car and run 20psi for long. in fact, you won't get further than 200 feet before overboost fuel cut (set for 17-18psi) made you wake up and take notice in a hurry. you need full exhaust, fuel mods, engine management, gauges, *****, brains, etc.
for most intents and purposes, 15psi on a stage 1 (ie no mechanical mods) is safe.
16.5psi with no cats. set max boost in 4th gear. there is no reason you should be flooring your car in 5th gear.
hth
ken
Old Mar 17, 2006 | 06:08 PM
GasPipe DreameR's Avatar
Car Info: lowered blk04 with no motor
i had one by turbo xs. than sold it. really gotta watch the boost gauge would over boost blah blah. the engine managment was way better. the mbc was a waste or 100 bucks
FuturistiK_STI
Jun 30, 2011 08:45 AM
G-money
Mar 10, 2003 06:04 PM
NRTmotorsports
Feb 22, 2003 11:37 AM
montyj
Jan 6, 2003 11:35 AM
100
Dec 31, 2002 10:00 AM
