Manual boost controllers
Old May 12, 2004 | 04:47 PM
dmcmahan12's Avatar
Car Info: 2008 OBP STi
What or how do the rest of you feel about using a mbc? My mods are Perrin I/C hoses, K&N filter, and silencer elbow delete. Have it set at about 17 PSI and take it easy as not to give it partial throttle because it goes to full boost in any gear now. Am I heading for disaster or is it safe? Please help ease my mind.
Old May 12, 2004 | 04:52 PM
namitherussian's Avatar
Car Info: Black WRX
from reading numerous posts here, i have learned it is worthless and a waste of money
Old May 12, 2004 | 04:53 PM
dmcmahan12's Avatar
You sure as hell can tell the difference between 14PSI and 17PSI!
Old May 12, 2004 | 04:55 PM
RoadSpike's Avatar
at 17psi you better have an upgraded turbo from my understanding or be looking to replace in a year or two when it burns out
A safe psi probably maxes out around 15.5 but i can't be sure.
Also a accessport or another ecu reflash is definitely better than just boost
Old May 12, 2004 | 04:58 PM
dmcmahan12's Avatar
But with a child on the way money is a big issue, if you understand where I am coming from.
Old May 13, 2004 | 06:26 AM
ride5000's Avatar
i wouldn't on an 04. too slow to open loop fueling.
Old May 13, 2004 | 07:11 AM
Mulder's Avatar
Car Info: 02 WRX WRB
If money's tight you'd best turn that thing way down, to stock boost levels or just a bit above.
17 PSI on a stock turbo with an MBC and no management is really asking for it with potential detonation (which you may not hear when it happens) and high EGTs. As stated there also may be more danger from this on an 04 due to the different factory fueling setup.
Spend a bit more now for safe engine management, or at least a good EBC using conservative settings, to avoid being in a situation with a blown motor and a new baby.
Or, just go back to the factory boost control and enjoy your car as it was made.
Old May 13, 2004 | 09:06 AM
wrx21's Avatar
Car Info: 2004 Impreza WRX
Access Port .. Its not that expensive when you consider the cost of fixing a blown engine. There are actually some people runing the AP and an MBC and thay have had some luck with it. I wouldn't mess around with an MBC right now though.
jackel23
Jun 30, 2008 09:57 AM
FIA-WRX
Engine and Drivetrain
Jan 9, 2007 12:56 PM
Wired Ricky
Vendor Group Buys/Specials
Nov 5, 2004 02:41 PM
spankaveli
Sep 26, 2004 06:17 PM
fatcatturbo
Jan 6, 2003 03:20 PM
