Agency power manual boost Controllers
Old Jan 9, 2007 | 12:56 PM
FIA-WRX's Avatar
Car Info: 05 sti
Agency Power brand new Manual Boost Controller is now available for your turbocharged vehicle. Designed with performance, fitment, and style in mind, the AP MBC will give your turbo vehicle some much need horsepower with a couple of easy twists of the unique adjustment **** not seen on any other manual boost controller.
How does the AP MBC work? Simple! The MBC is a bleed valve design, which has you connecting the hoses on either side to the compressor and the wastegate of the turbo. The MBC controls the airflow through the valve by the adjusting ****. Loosen the **** and more air moves for higher boost pressure. Tighten the **** down and restrict the flow for less boost pressure.
The AP MBC includes 2 feet of 5/32 vacuum tubing, a flexible aluminum bracket that bolts to the MBC and has predrilled holes for universal fitment, and hardware.
95.00 dollars shipped.
jackel23
Jun 30, 2008 09:57 AM
Wired Ricky
Vendor Group Buys/Specials
Nov 5, 2004 02:41 PM
spankaveli
Sep 26, 2004 06:17 PM
dmcmahan12
May 13, 2004 09:06 AM
subarustore.com
Sep 18, 2003 10:50 AM
