Low VAC, Turbo Stutter, No Power?!
Old Sep 7, 2009 | 02:54 PM
935BlueWRX's Avatar
Car Info: RA Hybrid Bugeye!
so i have an 02 subaru wrx had the engine rebuilt a while ago and recently ive been having problems with it.. it all started when i had low vacuum which is reading at 15 instead of the normal 17-18.. at the same time my valve cover gasket had cracked and leaked out a lot of oil.. since then when i try to floor it my car doesnt produce a lot of power and has this stuttering noise while its trying to go.. also while it stutters its hesitant and jerks around a lot while trying to boost. Please Please Please if anybody knows what could be wrong id like to know! i thought it was the turbo since one day i was no longer producing any boost so i thought it had seized up and was no longer working but after it had replaced the turbo its still having the same problem..
Mods are: Intake, DP, Boost Controller.
Old Sep 7, 2009 | 04:42 PM
wrxisthebest's Avatar
try disconnecing your boost controller and going back to stock to see if it changes..
either your ECU hates the boost controller(most likely) or you boost controller is leaking...
Old Sep 8, 2009 | 01:23 AM
935BlueWRX's Avatar
i had taken off the boost controller and im still having problems. low boost hesitant on acceleration etc..
Old Sep 8, 2009 | 05:47 PM
go completely back to stock if you can...
without tuning the downpipe, intake and boost controller are not great.
from there i would get a smoke tester, local tuners such as GST, DBTuned, etc will have one. they will help you find a vacuum leak. it puts 2psi roughly of compressed air into the vacuum/boost system with smoke and will show you leaks. if you leak at 2psi then you know you will be leaking at boost
Jebb209
Oct 23, 2007 07:10 PM
burndtjamb
Dec 27, 2005 02:18 PM
black02
Nov 3, 2005 07:34 PM
vixhex
Jul 7, 2004 10:32 AM
iratika
Jun 4, 2003 02:08 PM
