Low frequency humm under acceleration
Old Dec 20, 2007 | 05:12 PM
heat's Avatar
Car Info: 2002 Subaru WRX Silver
Question Low frequency humm under acceleration
I have a 2002 WRX with 105K miles.
Haven't driven the sucker for a week, and when i was driving to work this morning I noticed a low frequency noise under acceleration. It only happens under load. If I'm in neutral or clutched in, revving through the whole range sounds ok. But if I'm in gear, and step on the gas, I can hear a distinctive humm anywhere between 2500rpm - 6000rpm or so.
Any ideas?
Thanks in advance.
--Dima
Old Dec 23, 2007 | 05:47 PM
theo79's Avatar
Car Info: 2002 wrx
um
could it be your turbo?
Old Dec 23, 2007 | 07:35 PM
EBTurbo's Avatar
Car Info: 93 EG8
tires or radio?
EB Turbo
Old Dec 24, 2007 | 01:30 AM
heat's Avatar
Not radio
Turbo eh? Well, it seems that it can still build up pressure. Is there anything I can check? Or do I have to take my car in?
--Dima
Old Dec 24, 2007 | 07:01 AM
EBTurbo's Avatar
Car Info: 93 EG8
Some tires are just noisy, my A048's make lots of noise but, thats just because of the stiff sidewalls. there is nothing wrong with the tire. you should still get them checked out.
EB Turbo
Old Dec 24, 2007 | 07:44 AM
VRT MBasile's Avatar
um, I think if it were tires it wouldn't happen like it did (not doing it one day, then he doesn't drive it, and then it does it) unless he changed the tires in that one week period. I would narrow your search down to something else rotational since its only when you're moving (like something in the driveline or tranny).
I'd suggest taking it up to LIC in Novato and have them look at it
eastbaysubaru
Jan 15, 2011 12:03 PM
willieb925
Jan 27, 2009 04:11 PM
knele21
14
Feb 8, 2007 11:17 PM
Xury
May 28, 2006 09:57 AM
