Loping Idle and stumble NOT under boost
Old Apr 28, 2003 | 01:33 PM
Pi7467mp's Avatar
Car Info: 2000 2.5 RS USDM STI block, SOHC heads GT25 Ball bearing turbo, TMIC, TXS BOV, Tial wastgate, etc...
Unhappy Loping Idle and stumble NOT under boost
My car is pissing me off.... I can barely drive it unless I floor it.. when I am idling it is lopy, and when I am at partial throttle ( normal acceleration) my car jerks, bogs and hesitates. So then I floor it and it is normal and fast as hell. There is a company called endyn (www.theoldone.com) that specializez in honda superchartger upgrades, and one suggestion they have when running a high volume fuel pump, to drill a pressure relief holr in the FPR, thus decreasing idle fuel pressure.. So I did this on my old acura integra (supercharged) and my erratic idle was cured... so then I tried it on my suby, and it seemed to work, but now I get this ****ty drive, and it is embarrasing. Could this be why there is a lopy idle, and horrible acceleration? I did throw a code p0130 which is malfunctioning O2 sensor, bank one sensor one.. so I pooped out my eu and saw there was a bad connection ion that wire.. ( ****ty splice job) so i repaired it and the light went off. but my car is still running like... it is either not getting any fuel under normal driving, or no spark... help help help help help!!!
Attached Thumbnails Loping Idle and stumble NOT under boost-pass%2520close%2520up%5B1%5D.jpg
Old Apr 28, 2003 | 08:47 PM
Pi7467mp's Avatar
I figured this was the problem..... but I have had this mod on my car for quite some time, and it only started loping and running ****ty the past month... could this be because I fixed the CEL, and now my car is in "freak out" mode because it doesn't know what is going on.. ig, the presure drop?? and does anyone know where I can get either a stock or adjustable FPR, preferably one that has a fuel gauge built into it. Is there anything else that could be wrong?
Old Apr 28, 2003 | 09:01 PM
Pi7467mp's Avatar
No I haven't had any detonation, My plugs are in great condition and I havea timing device that retards timing per pound of boost, and I have it set at 3 degrees PPB, and I am only running 6 psi.. Could my Primary O2 sensor be bad?
Old Apr 28, 2003 | 09:02 PM
Pi7467mp's Avatar
also when i am accelerating it sounds like it is missing.. Could this be bad plug wires ? Just curious
Old Apr 28, 2003 | 09:06 PM
Pi7467mp's Avatar
Yes, it is a MY00 RS with a turbo kit. I posted this in the WRX topic room because I get faster replies and better information.
Old Apr 28, 2003 | 11:50 PM
Pi7467mp's Avatar
sorry about the confusion. and thank you for the replies.. I have a 2000 2.5 RS with 27000 miles. I have a walbro RRFPR set at 7:1 ratio. GT25 dual ball bearing turbo, Tial wastegate, 2.5 Inch cat back exhaust. Top mount intercooler, and Turbo XS blowoff valve.. I also have a timing device that will retard boost per psi, set at 3 deg, per psi. I have a voltage clamp set at 4.2 volts.. I have NOT thrown any codes other that p0108.. does this help??
Old Apr 29, 2003 | 08:26 AM
Pi7467mp's Avatar
bump
chuckc0313
Hawaii Classifieds
Feb 3, 2015 08:59 PM
bburke
Dec 19, 2006 04:55 PM
jrb619
Dec 15, 2006 02:12 AM
Impreza_WRX_STi
15
Jul 21, 2005 08:43 PM
DsmWRX02
Mar 24, 2004 04:01 AM
