Knocking / Tapping sound in Engine
Old Dec 16, 2005 | 04:05 PM
bluebiker's Avatar
Car Info: 2002 Subaru Impreza WRX - WRB
I have an 02 WRX, and it has started to get a tapping sound when it is running (from engine) popped the hood, and listened. It is consistent with revs. As the revs go up, the tapping sound gets louder and faster.
The check engine light has lit up now, and so I do not want to start the car.
Any suggestions for troubleshooting this? The car has oil, and i keep it regularly maintained. Maybe a piston broke off? (someone told me this...) i did not know this was possible?
Old Dec 17, 2005 | 03:10 AM
black dog's Avatar
engine noise
Its hard to diagnose trouble without hearig it in pereson. High pitch ticking could be valvetrain trouble. Low knocking would suggest piston or rod damage. If you cant get help from your warranty, bring it to my shop! We're in Pleasant Hill. 925.676.2782
Good luck!
ben@twothreetuning.com
Old Dec 17, 2005 | 05:24 AM
ipozestu's Avatar
Car Info: Broken Subarus
I think there is some bad gas roaming around. I recently got a loud fluttering sound from about 3000 to 4000 rpm. It sounds to me to be coming from the throttle body. Sounds like a really bad vibration. I heard it on the highway yesterday, thought it was coming from my brake install, further investigation lead me to the throttle body. Anyone got a fix for part throttle vibration?
Old Dec 17, 2005 | 04:12 PM
black dog's Avatar
throttle vibe
It could be related to your bov. If its releasing boost presure than your throttle body will flutter.
Old Dec 19, 2005 | 11:24 AM
WREXNFX's Avatar
Car Info: 05 WRX Wagon and 08 Civic Si
possibly the wastegate flutter ive read about
Old Dec 19, 2005 | 12:09 PM
rexmaster's Avatar
Car Info: 05 stg 2 wrx
I have a similar situation. I'm hearing ticking sound and the sound interval goes faster as I step on the gas. It almost sounds like putting a flexible tape hitting the fan. Is this injector sound in the cold weather? This is my first winter with this car.
Old Dec 19, 2005 | 12:12 PM
bluebiker's Avatar
it seems to be the lower tapping, not so much a ticking...
and i did notice loss of power... pretty signifigant loss. I was pretty nervous, so i stopped driving, and had the car towed.
Old Dec 21, 2005 | 12:44 PM
lightning_wrx's Avatar
Car Info: 2002 Subaru WRX
tapping knocking
1. start the car
2. put the e brake on
3. put the car in first gear and slowly let the ctutch out if the sound gets louder that means you have bottom end damage. If it goes away it means that the crank, rods, and pistons are fine.
4. if it gets louder do no drive it because it could let loose at any time
Hope this helps
Old Dec 21, 2005 | 03:22 PM
DanyoCantDrift's Avatar
The weal amewican hewo!
weird, this sound is similar to what i am hearing in my 97 ranger...it comes and goes, but as i accelerate it gets louder...ne ideas??
dpulse2930
Apr 9, 2011 12:18 AM
subbiedood
Mar 5, 2010 11:02 AM
JohnQGearhead
May 24, 2006 09:37 PM
y2Ldude
Oct 16, 2005 09:51 PM
aussiebrydon
Feb 9, 2005 10:14 AM
