Just threw check engine light
Old Jun 24, 2005 | 01:40 PM
anthonymx's Avatar
i have a 04 wrx with an up-pipe , down-pipe and catback, and i have a cell fix for the o2 sensor and a exhaust leak, haha. i was driving normal and then the check engine light just turned on the only thing i can think of is maybe the o2 went bad maybe? can anyone help me out
Old Jun 24, 2005 | 02:06 PM
WREXNFX's Avatar
Car Info: 05 WRX Wagon and 08 Civic Si
fix the exhaust leak and check your connections to the cel fix alot of times the wires break off the resistor.
have you gotten a reflash yet??
Old Jun 24, 2005 | 04:04 PM
anthonymx's Avatar
not yet
Old Jun 24, 2005 | 08:26 PM
MO REX's Avatar
Car Info: 02 PSM WRX
If it’s not the cel fix have the code pulled then click on this https://www.i-club.com/forums/engine-power-ej20t-pre-2006-wrx-jdm-60/complete-list-all-subaru-obd2-error-codes-44311/.
Do you have the oe egt probe installed in your aftermarket uppipe? If not you will need a cel fix for that also.
Old Jun 24, 2005 | 10:16 PM
playa7's Avatar
Car Info: JBP 04' WRX
pull the code...meet up w/ someone who has an access port or a code puller thingie and the code will tell you what you need to fix post up the code if in doubt...
ryball
Jul 2, 2009 12:35 PM
saab92x
Mar 16, 2009 03:16 AM
Lboogie
Nov 26, 2008 03:49 PM
06scooby
Oct 15, 2006 10:11 AM
Proj.JDM_STI
Oct 8, 2006 01:14 PM
