Just Purchased first WRX, couple issues
Old Jun 7, 2005 | 12:25 PM
abbfanuc's Avatar
Car Info: 05 wrx blue
Originally Posted by Suby8495
I finally picked up my first WRX yesterday. Its an 02 blue sedan w/ 70k miles. Managed to get it for only $9700. Anyway, at low speeds when going over little bumps (or big bumps), there is a knocking sound coming from somewhere in the rear. Sounds like something metal bouncing around in the spare area, but theres nothing in there. What would be the probable cause for this? Other than that, it seems like a good car so far. Once i get the decals off and some real mods on, it should be a great car.
it's probably just your muffler hitting one of the hangers. you can just get the kartboy hangers. they are much more stiffer than stock.
Old Jun 7, 2005 | 12:54 PM
WindingRoad's Avatar
Car Info: 2004 White GDB
my car made some knocking noise too, but i looked around in the rear and it was just a loose jack. if you have the jack tools in your rear spare tire area, they will make noise too.
Old Jun 7, 2005 | 12:55 PM
btw. 9700 is a great price.
Old Jun 7, 2005 | 04:39 PM
Dice's Avatar
Car Info: 2002 WRB WRX
i got my 02 and its been making a horrible clanking sound when i go over bumps...i put my new exhaust on today and when it was on the lift i took a look (front left wheel) and it turned out i had bad lower ball joint...new part was like 50 bucks and everythings is good again...btw the greddy evo2 sounds sick
Old Jun 7, 2005 | 06:26 PM
REx fetish's Avatar
$9700 jesus christ!!!!!.thats less than my used 01 rs that i got.
Old Jun 7, 2005 | 08:48 PM
norcalridin's Avatar
but its got 70k miles on it.. not the worst.. i bought myne with 51k on it for 12,000.. and its in good condtion, has a few flaws but they are worth saving the money to go towards parts..
Old Jun 7, 2005 | 11:59 PM
meilers's Avatar
ill prolly go get it checked out once I get my Maxima back. As long as the driveshaft isnt falling out ill be happy. Ive tried kicking the muffler, rocking the car, but I cant duplicate the damn sound to find where it is. Also, is it normal to hear a higher pitched metallic vibrating sound coming from below the shifter at highway speeds? Well, of couse its not... but I wonder whats causing it (?).
Your shift **** is loose, tighten it :-)
No, really!
Old Jun 8, 2005 | 06:07 AM
andrew12's Avatar
Car Info: 2004 jbp wrx
does the car have any aftermarket mods to it? if there is a rear sway bar in there, then it could be the bushings needing to be greased again... or the bar hitting something... its a common problem with certain sway bars
rourich
Sep 22, 2013 10:08 PM
sicwrx_04
Aug 7, 2006 09:15 AM
soccrstar
Jun 2, 2005 10:16 PM
WRXWagon203
Jul 5, 2004 10:58 PM
Sti-nkinPhast
Aug 12, 2003 06:57 PM
