installing stock bov question (help)
Old Jan 2, 2008 | 05:42 PM
gnabgibeht's Avatar
Car Info: 2013 WRX Hatchback
Red face installing stock bov question (help)
I am installing my stock BOV and one of the hoses came out, so quick question to anyone who can help. The thin hose goes directly into the manifold? I see a hole where the hose can go from the stock BOV into the manifold... I did some research and saw that the hose went into a split, but I don't see that on my 05 wrx anywhere. SO right now I have the big hose connected , and the BOV mounted, but the little nipple with the hose is where I am lost. I don't know where the end should go...
thanks for any replies
Old Jan 2, 2008 | 06:43 PM
stealthrex68's Avatar
Car Info: 02 bugeye with tune by Ed
If you are replacing an existing aftermarket bov with the oem stock bov, it should be just reinstalling the t-fitting that should be located to the right of the bov.
Old Jan 2, 2008 | 07:00 PM
gnabgibeht's Avatar
yup... thats the thing. i dont see any T fittings... i just have one hose that "I THINK" came off the manifold... =\ should i be worried if there is no T shaped hosing?
Old Jan 2, 2008 | 07:12 PM
no actually. I screwed up. I have a t fitting on mine because I'm running a boost gauge so i need the t fitting to connect a vacuum line. Sorry for the bad info!
Old Jan 3, 2008 | 10:46 AM
gnabgibeht's Avatar
i think i got it installed... but one question is... i found a little oil just in the hose from the tmic hose... is that normal? and the vacuum hose that connects to the BOV right under the tmic hose
alaskanwhitey
Aug 21, 2014 01:52 AM
Dans Rex
Nov 11, 2008 11:27 AM
mhl23
Aug 21, 2006 11:29 AM
aznsensation18
Oct 31, 2005 06:25 PM
rephlex
Jan 13, 2005 09:18 PM
