Installed Helix DP today (YAY!!!)
Old Feb 28, 2003 | 05:52 PM
Stevied's Avatar
Car Info: 4 wheels
pics?
BTW: Does this allow you to keep the 3rd cat?
Old Feb 28, 2003 | 06:12 PM
hokusai's Avatar
Car Info: a Ford
no it does not. pics can be seen at www.gruppe-s.com
Old Feb 28, 2003 | 10:52 PM
protocol_droid's Avatar
lubricant and a breaker bar are a must for the seized bolts if an impact wrench is not available.
Old Mar 1, 2003 | 12:07 AM
Thumbs up
Yes, the ones on the top portion of the turbo are difficult. The breaker bar was used on the downpipe side while a box end wrench was used on the other side. It worked wellwith liquid wrench...I sprayed a buttload on there and just muscled it until it budged and then finished the rest with a regular wratchet... albeit my car only had ~5000 miles on it before I did the change. Perhaps you can have someone hold the box end wrench while you give it all of your might on the downpipe side with the breaker bar. My bar is >2ft in length for ultimate force through a distance. I think a standard long torque wrench should be sufficient as well.
Old Mar 1, 2003 | 04:36 PM
Yes, I had to trim the turbo heat shield. Make sure you have a dremel handy.
Old Mar 1, 2003 | 08:14 PM
ScoobyBoy's Avatar
very interested in buying this.
any cels yet? so theres no possible way to install the dp w/o trimming the heat shield?
Old Mar 1, 2003 | 09:55 PM
scoobiesnacks's Avatar
You could leave the heat shield off but the intercooler wil soak the heat from the turbo. If you plan on putting it back then yes you have to cut it.
Old Mar 2, 2003 | 12:15 AM
That is correct. The helix is bellmouth and the opening on the stock heat shield is only slightly larger than the stock 2.5 inch piping. With a dremel, it only took two cutting discs and <10 minutes of cutting.
wrecker83
May 7, 2010 10:09 AM
gruppe-s
Engine and Drivetrain
Aug 11, 2006 05:34 PM
w1ngzer0
Mar 14, 2006 06:13 PM
sybir
Oct 12, 2004 04:07 PM
boardoholic
Dec 7, 2003 06:01 PM
