Install order??
Old Dec 22, 2006 | 05:47 PM
4Subaru's Avatar
Car Info: 2004 WRX Silver
Install order??
Im going to be installing new struts and springs ect, plus an up pipe down pipe and exhaust and defi gauges. My question is should I do the suspension first or the engine mods. How should I go about lifting the car to work on it, ramps jack stands? thanks for any help.
Old Dec 23, 2006 | 03:01 PM
4Subaru's Avatar
I guess no one has done both installs at the same time? I was thinking with the suspension first, but i was here to see if someone had any input on the subject. thanks
Old Dec 23, 2006 | 04:03 PM
Superglue WRX's Avatar
Not sure if it makes a difference, but try removing the shocks and struts before installing the up/down pipes to maybe give you more room under the car. I don't think anyone's commented becase it shouldn't really matter which one you do first.
Old Dec 23, 2006 | 06:28 PM
mgb04's Avatar
Car Info: 04 STI, 03 M3, 08 335i, 15 i3
i agree with superglue in that it may help a little bit to take the struts off the car before you do your exhaust work. after that, just give all your instructions a once-over to see if any of your parts-to-be-installed are in the same vicinity and which would make sense to do first.
in the end though i don't believe it'll make that much of a difference if you do one set of parts over another.
Old Dec 23, 2006 | 10:38 PM
4Subaru's Avatar
alright i think i'll start with the suspension, thank you all for your input. It seems everyone says to go ahead and do the suspension install first. Thanks Again!
OneManArmy
Aug 7, 2013 03:32 PM
Maoziyboy
Feb 15, 2008 02:47 PM
dedfish
Sep 10, 2005 03:42 AM
wckdwrx
Nov 26, 2003 04:53 AM
wckdwrx
Nov 25, 2003 10:14 AM
