Install help?
Old Dec 5, 2003 | 07:58 AM
wvjnky's Avatar
Car Info: 02' Black Wgn
Install help?
I am getting my up-pipe down-pipe today to install tonight. Any helpfull hints that will make the install eaisier. A walk through the basics would be great. Thanks
Old Dec 5, 2003 | 08:04 AM
Daredevil's Avatar
get an o2 sensor socket, helps a LOT!!!! costs like 10 bucks at kragen
make sure to hve new gaskets
do you haev a lift or no?
and what up pipe and downpipe?
Old Dec 5, 2003 | 08:27 AM
wvjnky's Avatar
HKS up and down. What is an 02 sensor socket? No lift, just jack stands.
Old Dec 5, 2003 | 08:52 AM
Daredevil's Avatar
hks Bleh
well
it'll take longer this way (without a lift), i did it this way too
i had help cause i've never gotten under the hood of car before and ill see if i can remember some stuff off hand without lookin at it
-take of the I/C
-take off heat shield.
-remove bolts to DP both at the turbo side and catback side
-take off downpipe
-dunno if you hvae to recut the heat shield or not with HKS
-undo the studs from turbo to Up pipe
-get underneath the car and remove the plastic guard crap
-remove o2 sensor (o2 socket:it is a socket with a slit down the side so you can remove the o2 sensor, it makes more sense when you're down there)
- to do the above its easier to turn th wheel's all the way to the right and remove soem plastic coverings
-remove turbo, you will lose some fluid (lots in my case) (radiator fluid)
-undo the up pipe from the exhaust manifold (i think that is what its called)
-take studs out of the old up pipe (you can reuse these)
-go backwards
im prolly missing some steps but thats the just of it
Old Dec 5, 2003 | 09:16 AM
wvjnky's Avatar
What's the deal with the HKS. I saw two types of dp's out there, bellmouth and this type, it seams like the generall shape of the actuall pipe is the same. It was about the $ and cents though. I mean half the money for what looks like the same peice.
Anyway, thanks for the how too. It will be much help. I'll post on monday with the after math
Old Dec 5, 2003 | 09:37 AM
Daredevil's Avatar
hks is not belmouth...
if you saw a bel mouth next to the HKS or stock DP, you would change your mind
Daredevil's Avatar
where are you anyways? maybe i can lend a hand?
Old Dec 5, 2003 | 09:45 AM
wvjnky's Avatar
San Diego.
Old Dec 5, 2003 | 01:24 PM
wvjnky's Avatar
[i]
[/B]
do I have to prime the turbo with fluid before reinstalling it?
Old Dec 17, 2003 | 12:55 PM
WindingRoad's Avatar
Car Info: 2004 White GDB
will the hks downpipe throw a cel?
Old Dec 17, 2003 | 02:22 PM
ScoobyBoy's Avatar
all dp's that get rid of cats will throw a cel, except for the godspeed.
Old Dec 17, 2003 | 05:51 PM
theworx's Avatar
Car Info: 04 Java Black Sedan
Stupid question, but what is Godspeeds web address?
jdmdaddy
Mar 14, 2014 11:29 AM
unstble
Mar 21, 2008 09:09 AM
Salty
Jul 8, 2003 02:50 PM
spdkills
May 23, 2003 09:41 AM
