importance of BOV?
Old Nov 23, 2003 | 03:34 PM
samagon's Avatar
importance of BOV?
at what point does the BOV become more than a sound enhancement?
my plans are to get the perrin IC hoses, an up-pipe, a TBE, and a cobb computer thingy, I already have the STI scoop.
so with these mods on my car, will I see any positive returns (other than the cool sound) from a BOV?
and (I can probably get this one through a search, but if someone wants to answer I would appreciate it) what are the typical gains that one receives from a BOV, I have read that it reduces boost surge, what is that, exactly and how does it harm the engine?
thanks for any and all answers! :banana:
Old Nov 23, 2003 | 07:06 PM
There is a performance gain to be had IF you are running high boost, like 19 psi plus... but if you are doing that, you already have a turbo, complete exhaust, uppipe, injectors, pump, etc. etc.
The reason the car has a bypass valve (the proper term) is to protect the turbo from compressor surge. When you snap the throttle closed, the boost can't pass through it, causing a sudden spike in pressure between the compressor and the throttle body. This pressure slams into the compressor blades and eventually can cause damage to the turbo. That takes a lot of boost and repetitive use to really break things though.
kyoung05
Sep 5, 2008 09:10 PM
xqwizit
Dec 12, 2007 10:02 AM
iLoqin
Oct 2, 2007 07:46 AM
subiedave
15
Oct 20, 2005 07:56 AM
Paperchasin
Oct 6, 2005 09:56 AM
