im gonna blow it up!!!!
Car Info: 2013 STI
Im so tired of trying to figure out what the problem is with my 02 wrx that im ready to blow it up (not serious, just an expression people
). Okay here's my problem......I keep getting a cel (misfire in cylinder's 2/3). The car never freaks-out, nor does it affect the driving or performance/idle....not sure wtf is going on
. I just got back from a trip to idaho (780 miles one way) and I didnt get a single cel. Today I'm heading to Subaru to buy some new oem spark plugs (current plugs only have 13k-might be time to change...what do u think?) The car is pretty much stock as far as the engine goes....here is a list of my current setup;
Brakes & Wheels:
Rotora Slotted Rotors & axis brake front and back
Goodridge stainless steel brake lines
Prodrive P7 wheels in silver
BFgoodrich G-Force sport
Light weight wheel lugs & locks
Drivetrain:
ACT streetlight flywheel
ACT prostreet clutch
Kartboy short shifter and bushings
Razo racing pedals
06 STI transmission
06 STI axles (4)
06 STI driveshaft
06 STI dccd w/controller
06 STI hub’s and knuckles
06 STI struts
Engine/Power:
Dual-tip turboback exhaust
Interior:
Recaro SRD racing seats x2
OEM Carbon fiber interior trim
OEM Arm rest extender
OEM Premium sound system with a 6 CD changer
OEM Gauges (boost, volt, oil temp)
Suspension:
Cusco sway bars front and rear
Cusco front crossmember brace
Perrin endlinks
Whiteline anti-lift kit
Whiteline steering rack bushings
Whiteline rear strut bar
Hotchkis rear camber kit adjust bars
Swift Springs
. I just got back from a trip to idaho (780 miles one way) and I didnt get a single cel. Today I'm heading to Subaru to buy some new oem spark plugs (current plugs only have 13k-might be time to change...what do u think?) The car is pretty much stock as far as the engine goes....here is a list of my current setup; Brakes & Wheels:
Drivetrain:
Razo racing pedals
06 STI transmission
06 STI axles (4)
06 STI driveshaft
06 STI struts
Engine/Power:
Interior:
Suspension:
Perrin endlinks
Swift Springs
ok.. the turboback without Engine management is not good, but i bet the Lightweight flywheel is ur problem.. lightweight flywheels are known to cause misfires. it would be better to have just gotten an oem flywheel...
get the new plugs and if it still happens, its probably ur flywheel.
but like i said at first, if u dont have engine management then dont run the turbo back exhaust
Car Info: 2013 STI
-marcus
Car Info: 2013 STI
Car Info: 2002 WRX (RIP) // 2007 STi "OMGASTI"
i just had a bunch of random cel's popping up with misfires, turns out after like 5 times to the dealer it was sticky valves
edit: when my cel's were on it wasnt running particularly rough, just not perfect. it wasnt noticable
