im gonna blow it up!!!!
Old Dec 6, 2008 | 07:24 AM
tkmotorhead's Avatar
Car Info: 99 impreza 2.5rs
if you are using stock ecm map-- there is an updated program for that problem.
the lightweight flywheel will do exactly what your car is doing aswell.
its the flywheel
Old Dec 13, 2008 | 02:35 PM
Konrad_WRC's Avatar
time for an cylinder leak down on an hot and cold engine you could have valves not sealing or piston rings do this test and save all the guessing games. Misfire is an bad things for an engine ecu sees miss and retards timing to prevent detnation you will cause engine to blow.
Old Dec 15, 2008 | 05:26 AM
Konrad_WRC's Avatar
another things u may check are injector seals that sit in the tgvs they are not reuseable and will cause an lean condition and let a missfire check all four spray so starting fluid in theinjector and if it bog u have an leak.
Old Dec 30, 2008 | 09:37 AM
Chrisnonstop's Avatar
Car Info: 02 Silver WRX sedan. Eibach springs, Blitz NUR cat back, Rota 17" Attacks, Cobb AccessPort/DP
Stop the madness...02's are notorious for throwing what I like to call "phantom cel's". Since day one off the lot my 2002 would throw the exact same cel's. Before I realized it was a "glitch in the programming", I took it to the dealer a couple of times only to have them work on it and find nothing wrong. When they initially saw the codes they told me they may have to do extensive warranty work....lol. Car has always run fine, although it's starting to show it's age at almost 200K miles
RallySportDirect
Engine and Drivetrain
Nov 24, 2009 12:54 PM
Ninosautoacc
Vendor Group Buys/Specials
Feb 24, 2004 10:39 PM
r_master
Dec 17, 2002 10:58 PM
Ninosautoacc
Dec 16, 2002 01:31 PM
Buddha
Nov 23, 2002 03:19 AM
