I want to wrap my headers
Old Apr 22, 2005 | 09:31 AM
AntiochCali's Avatar
Car Info: '03 WRX wagon, faster than walkin'
How much work is it to wrap headers?
How do you finish?
Start?
Any cautions?
I hear I need to "seal" them, with what?
why?
Old Apr 22, 2005 | 10:20 AM
SSFWRX's Avatar
Car Info: Sleeper Much?
Pet Peeve - HEADER....as in One(1) not multiple. The honda guys that say "headers" really irritate me.
Old Apr 22, 2005 | 11:33 AM
You are correct it is one piece...so I guess I should have said header or header pipes. Sorry for the peeve.
Old Apr 22, 2005 | 11:40 AM
SSFWRX's Avatar
no problem....now heres your answer You can use a sealant so that the water from the road and such doesnt allow moisture between the wrap and the header. Wrapping them should take about 30 minutes or so. You want to be sure to use gloves...the stuff they're made of isnt healthy to be touching all that much. Make sure you use good clamps or whatever is supplied in the kit to secure it so it doesnt unravel. The technique is hard to explain but easy to show....have Mikey Poo at GruppeS show ya.
Old Apr 22, 2005 | 11:41 AM
youpers's Avatar
Car Info: LGT STI
I got headers, their above every doorway in my house!
Old Apr 22, 2005 | 12:04 PM
platypus's Avatar
Car Info: dangerous with a wrench
Just a quickie - If you're running the stock WRX header pipes wrapping them will probably not result in much gain since the cast metal retains heat pretty well out of the box.
(You're probably not running stock header pipes, but this will also put this info into the search logs)
Old Apr 22, 2005 | 03:22 PM
SSFWRX's Avatar
stock would be considered a cast exhaust manifold....a header is an aftermarket piece made from round tubing usually constructed of stainless steel.
Old Apr 22, 2005 | 04:13 PM
1WRXNFX's Avatar
Car Info: 2000 2.5 RS (really slow)
just have your header thermal jet coated. Its much better then any wrap.
Old Apr 22, 2005 | 05:08 PM
Impala SS AutoX's Avatar
Car Info: 96 Chevy Impala SS, 06 GMC 2500HD (former 02 WRX)
Good advice. Wrap promotes rapid degradation (read that as RUST) of the headers. You're literally better off just installing them bare than wrapped.
On the other hand, good coating will last for years.
Old Apr 22, 2005 | 06:06 PM
wombatsauce's Avatar
Car Info: 2018 Golf R Variant
Check out Swaintech. I read about their coatings in GRM and they sound hot! Er.. Cool. Whatever.
I peeled the wrap off my 3S-GTE downpipe and found out why I won't ever be wrapping anything like that again.
Also - SpeedMerchant in San Jose said they would ceramic coat my TRD longtube header for my old Celica for around $150. For that, I can't see a reason to wrap them.
Old Apr 22, 2005 | 07:22 PM
All,
I am wrapping them, yes they are aftermarket, because since installing them my underhood temperatures have gone through the roof. Running the stock manifold I was running typical underhood temps about 90-110 degrees F.
After installing the headers I very often run temps of 140+ degrees in traffic and it isn't even summertime yet. I expect those numbers to continue to increase until I do something. I hope wrap will reduce the temps considerably.
dchoi23
May 11, 2010 10:36 AM
dezwrx03
Oct 2, 2004 02:17 PM
dezwrx03
Oct 2, 2004 02:16 PM
dezwrx03
Sep 5, 2004 07:41 PM
