I Need Help...
Old Aug 27, 2006 | 09:53 PM
IMpReZa EJ25's Avatar
I Need Help...
hey guys well i finaly purchased my 2004 wrx wagon after coming from a 2003 rs auto, ok well my question is when i hit boost it sounds like skiping of the turbo spoling i don't know if that makes sence but yah. my other question is how much boost should it b boosting, it came with the stock boost guage n i don't know the conversion to psi, well it goes to .1 then tapers down between (middle of .5 n .1) oh and btw i bought the car used it has 42,000 miles on it. just to make sure i'm safe with my purchase...or if it normal thanks in advance...
Barnaby
Old Aug 30, 2006 | 06:49 PM
help n e one? edit: it goes from .1mpa to .07mpa
Old Aug 30, 2006 | 07:02 PM
MO REX's Avatar
Car Info: 02 PSM WRX
1st you need to check the vac lines/fittings that run from the FBC (factory boost controller), WG (waste gate) and turbo outlet to make sure everything is hooked up correctly and snug. If everything looks OK you need to disconnect the FBC, run a piece of vac line from the turbo outlet directly to the WG. If boost holds steady at around 7.5 psi you know the WG is functioning properly and the problem is elsewhere. Next try to get someone to lend you their FBC for an hour and see if the problem persists.
When this happened to my 02 Cobb stage 2 WRX it was just a vac line that streched out a bit at the T so hopefully you luck out like I did.
click on this https://www.i-club.com/forums/engine-power-ej20t-pre-2006-wrx-jdm-60/boost-fluctuation-who-really-knows-138824/
BTW, stock boost is around 13.5 pound/square inch = 0.093 079 223 megapascal you're running 0.1 megapascal = 14.503 773 801 pound/square inch so your overboosting and seeing a boost spike.
http://www.onlineconversion.com/pressure.htm
unstble
Mar 21, 2008 09:09 AM
resident smurf
May 30, 2005 08:17 PM
Eggman's-STI
Oct 5, 2004 10:43 AM
disque71
Apr 13, 2004 11:27 PM
brucelee
May 28, 2003 09:47 PM
