I hit 18 psi !!
Old Nov 22, 2004 | 06:12 AM
polarpreza's Avatar
I hit 18 psi !!
I currently have gutted uppipe, replace the downpipe after turbo and stock last
cat and a cat back exhaust, IC hose, I hit 15psi on 1-3 gears pull with some boost
spike, but on 4 th and 5 th gear when I floor it past 5000rpm, the boost just
keeping going up and hit 18psi+( fuel cut) , anyone know if thats an wastegate
issues ?oR something else ? BTW it was in cold weather under 7 degress.
Old Nov 22, 2004 | 10:07 AM
mmboost's Avatar
Do you have any boost control other than stock stuff?
Old Nov 22, 2004 | 12:41 PM
ive hit 27lbs on the stock turbo
take off the turbo and grind around the wastegate........ have a pro do it
Old Nov 24, 2004 | 02:35 PM
polarpreza's Avatar
NO boost controller . never had one . its hitting 19 yesterday ..lol ..... anyone know what to do . ? or sth that a boost controller can be fix or . its my wastegate
Old Nov 24, 2004 | 02:41 PM
soggynoodles's Avatar
27 pounds of what?
Old Nov 24, 2004 | 07:05 PM
MonkeyAB's Avatar
Car Info: 2001 Impreza 2.5RS(Ti)
did you by chance do the 3/16ths "mod"?
Old Nov 25, 2004 | 08:54 AM
atreger's Avatar
Car Info: 02 WRX, BLACK
27 lbs!!!??!?!?!?
Old Nov 25, 2004 | 12:32 PM
XkrazyAsianX's Avatar
Car Info: SGM 135i
27 lbs of boost on the stock turbo .... maybe .. i sure hope you had some internals tho . cause that open deck aint gonna handle that .. no way in hell
Old Nov 25, 2004 | 12:47 PM
I don't think you could get 27lbs on a stock turbo. From what I'm told they peak at 18.
Old Nov 25, 2004 | 12:53 PM
JetBlue's Avatar
Yup. If it keep going over 18 psi then your stock turbo is not gonna last that long.
Old Nov 25, 2004 | 01:07 PM
Car Info: SGM 135i
i've gone over 18 psi .. actually over 21 psi .. 1.5 mpa on the stock turbo and all i have is upand down pipe, cat back, and lightened crank pulley. im not saying that the turbo will last at 27 psi .. im just saying can be boosted to that amount .. if you tweak with the wastegate a lil .. it's a stupid idea to have it run like that .. and you probably wont be able to go open throttle on the freeway . but hey you get quick *** spools lol
Old Nov 25, 2004 | 01:47 PM
MO REX's Avatar
Car Info: 02 PSM WRX
1) What he said^^^
2) Have you messed with the wastegate arm?
3) Did this problem start after a mod and if so what mod?
4) How many miles are on the car?
Old Nov 25, 2004 | 03:42 PM
myroncuz's Avatar
uh, i spiked 25 psi on the stock turbo as well... damn mbc was on upside down... lol
Old Mar 28, 2005 | 02:15 PM
ikes wrx's Avatar
Car Info: 02 wrx
Originally Posted by MO REX
1) What he said^^^
I've have the same mods as he has and I've done the 3/16 mod as well. I'm starting to get boost spike 18 psi in 2nd+ 3rd.
I didn't touch the wastegate arm, and it started after I installed an up pipe, the turbo back was installed first
I'm getting a little worried about it
I'm going to try a smaller "T"
Old Apr 4, 2005 | 07:37 PM
taerron's Avatar
After I installed my up and down pipes, I would spike to about 18psi. I had my car tuned and it has never done it since.
