How Much Restriction From Stock Muffler?
Old Apr 4, 2003 | 09:33 AM
blackwagonrx's Avatar
Question How Much Restriction From Stock Muffler?
My current set up is a 3" HKS DP connected to a fabricated 3" resonator pipe. I'm planning to replace the axle-back pipe with a 2.5" pipe. I want to leave the stock muffler on, because I don't want the coffee can look and can't afford an aftermarket axle-back right now like a Stromung or MRT. Whats the HP difference between my set-up and the same set-up with an aftermarket axle-back? Thanks for your inputs
-Victor
Old Apr 4, 2003 | 09:42 AM
inthedeck's Avatar
sounds like...
you may build up some back pressure there, becuase u are opening everything else up, except for the muffler. As a result of increased back-pressure, you are more than likely to get some fumes into the cabin, since there is not enough "room" for all the exhaust gasses to escape.
Might want to add a straight pipe, of find someone with a used "performance" muffler to avoid the above situation.
My $0.02.
later,
i.
Old Apr 4, 2003 | 09:56 AM
Re: sounds like...
My $0.02.
later,
i.
When you say straight pipe, Do you mean with/out a muffler?
Old Apr 4, 2003 | 10:04 AM
Originally posted by toekneepark
there was a post here a little while ago, about how much help opening the muffler was.. he did everything except the muffler (he was dyno'ing) and he said it opened up about 20 hp... so do a search and check it out... hhmmmmmm maybe it was www.clubwrx.com.. not sure.. one of those
WOW! That's a pretty good increase. Not a bad way to spend $200 (not including labor). I'll check that out. Thanks
-victor
Old Apr 4, 2003 | 10:05 AM
inthedeck's Avatar
straight pipe
= without muffler. When you add the 2.5" axleback, get an extention pipe, and that will replace the muffler.
Ask WRX Grl (can't remember if that's her ID) but she has a set-up with a mufflerless system.
Later,
i.
Old Apr 4, 2003 | 10:18 AM
Re: straight pipe
Later,
i.
Will I be able to run my car @ a race track with that set-up?
I know that Infineon and Sacramento Raceway requires a muffler.
Old Apr 4, 2003 | 11:12 AM
inthedeck's Avatar
dude...
check this thread out...they may be of some use...
Click Here.
later,
i.
Old Apr 16, 2003 | 10:53 AM
thebankman's Avatar
Car Info: subaru
I've got a straight pipe catback on my 02, looks good, sounds awesome, performance is probaby up a few horsepower, and I have to constantly watch out for police now even when driving slow. And the setup is cheap, probably $60 at a muffler shop for the piping and a stainless steel tip. Good times
gruppe-s
Apr 11, 2006 07:12 PM
gruppe-s
Engine and Drivetrain
Apr 11, 2006 07:10 PM
blackwagonrx
Mar 4, 2004 07:38 PM
godfather2112
Wanted
Jan 14, 2004 11:37 AM
godfather2112
Wanted
Jan 14, 2004 12:30 AM
