How to help my engine run cooler?
Old Dec 13, 2004 | 09:48 PM
subablunc's Avatar
Car Info: WRX 04
how to make mu car cooler ?
Hi guys,
Living in South Pacific where the weather is particularly hot, I need some tips to make my car cooler.
Any inputs ?
- easy solutions/more difficult solutions,
- cheap/more expensive solutions,
- quick/less quick solutions.
I don't plan to get a FMIC now. Maybe later
PS : I'll soon receive an air splitter + radiator shroud.
Please forgive my english...
Old Dec 13, 2004 | 10:33 PM
darksands's Avatar
Car Info: Subaru WRX 2005
heat sheild
Old Dec 13, 2004 | 10:47 PM
Imprezer's Avatar
Admin v2.0
Car Info: 02 Black Legacy GT
Get colder thermostat.
Get nice radiator.
Get better radiator fans.
Wrap your header, uppipe, downpipe.
Get oil cooler.
Old Dec 14, 2004 | 01:02 AM
rustokman's Avatar
Car Info: Black 03 WRX
Get this stuff called "Redline water wetter". Basically it helps break up the water molecules from sticking to eachother (a bunch of chemistry). It won't necessarily make your car run too much cooler, maybe a few degrees, but it will help eliminate certain "hot-spots" in the engine. There are plenty things about it all over the internet, do a google search and you will be sold on it. I think I paid like 4 bucks for a bottle at pepboys.
BTW, my engine cools down really really fast after adding it in.
Old Dec 14, 2004 | 03:30 PM
subablunc's Avatar
Car Info: WRX 04
where can I find better radiator fans ?
Old Dec 15, 2004 | 12:52 AM
Wingless Wonder's Avatar
Origami posted by subablunc
Intercooler doesn't affect your coolant or oil temperature. It's part of the intake system and might help power, depending on your other modifications.
If your referring to the Zerosports or replica type 'shroud', it might help a little bit but it works even better just to seal the gap between the radiator support and the radiator itself using some sort of gasket or heat-resistant foam that you can squeeze into that gap by hand. You might try a local home improvement store and look at the heating/air-conditioning section. Don't use anything permanent like silicone because you might have to pull the radiator someday.
Old Dec 16, 2004 | 11:10 AM
ish's Avatar
ish
get an oil cooler and just get rid of your thermostat.
Old Dec 16, 2004 | 03:31 PM
VIBEELEVEN's Avatar
Car Info: 03 WRX
Don't get rid of your thermostat
Old Dec 16, 2004 | 04:51 PM
MVWRX's Avatar
Car Info: '05 Crystal Grey Metallic WRX Sport Wagon
Hahaha, I second that...
Old Dec 17, 2004 | 10:07 AM
VIBEELEVEN's Avatar
Car Info: 03 WRX
Question
What's your typical water temp. ?
depdivr
Sep 29, 2005 10:52 PM
thunder_sti
Sep 25, 2005 06:51 PM
OuTkAsT WrX
May 10, 2005 12:24 AM
mazspeedpro
Apr 23, 2003 09:53 AM
BoOm
Feb 16, 2003 10:08 PM
