HKS BOV & intake, check engine light "HELP"!!!!
Old Apr 4, 2003 | 06:57 PM
WRX= Factory Turbo forum. Thank you drive through.
EDIT: Oh yeah, it's not your BOV unless it's somehow causing overboost. Cold air intakes on near-stock WRXs almost always cause a lean condition, and that is BAD. Reset your ECU and see if it learns how much air you're really flowing. If that doesn't work, you need to find a way to force more fuel into the combustion cycle. Or dump the intake on eBay.
Old Apr 4, 2003 | 09:50 PM
Disconnect your battery. Step on your brake pedal for a minute. Wait 5 more minutes. Reconnect and start up.
If possible, do this too: Immediately after your first restart, be somewhere that you can immediately get to 3rd gear at about 4000 RPM and be able to hold it for about 20 seconds. You will instantly gain horsepower.
Old Apr 5, 2003 | 09:02 AM
Mulder's Avatar
Car Info: 02 WRX WRB
Dude-
Instead of repeatedly resetting your ECU which will not fix anything, go and get the code read and post it, then someone can give you useful advice. Autozone should read the code for free, or you can post in your local area forum either here or on NASIOC and a local member with a scanner can read it for you.
The light will keep coming back on until you find and correct the problem that is causing it. It is most likely your short intake, as mentioned these are known for causing problems on WRXs. You may need to go back to your stock intake to solve this.
If you happen to be in the NYC/LI area I can scan the code for you.
Old Apr 5, 2003 | 11:50 AM
Yeah, if it came back you need to deal with the problem. I was hoping it was just one of the random CELs that get thrown for no real reason occasionally. Go to the dealer though, they should do it free under warranty. Barring that, buy your own code puller and check it yourself.
Old Apr 14, 2003 | 10:52 PM
cohlineman's Avatar
From: At the store trading the box of tissue in on some brawny!
Car Info: Platinum 02 WRX, Progress springs,JIC Bullet exhaust , STI shifter, Accessecu, Rota Sub Zero
Blitz
You will want a Blitz short ram intake or other reputable manufacturers' short ram intake to make room for the new IC.Plenty of room for your FMIC and no cel's.Older versions of the Blitz threw cel's but the portion which houses the MAF sensor was redesigned to flow correctly.I have had one (thanks Vincent!) with stock IC for 6k miles and in conjunction with a Forge bov for about 1k and still no problems.
Old Apr 16, 2003 | 12:26 PM
pepsi_blue's Avatar
Thumbs up
cel fix costs like 15 bucks. Buy it on ebay, there is a guy selling tons of them. Or if you are from the bay area call gruppe-S. All you have to do is buy it take off your second o2 sensor from your downpipe and tap it in. Instructions are included w/ the fix. It is real easy to do yourself. I just did mine 3 days ago, took me an hour.
Old Apr 16, 2003 | 01:50 PM
Mulder's Avatar
The $20 CEL fix is ONLY for the P0420 catalyst inefficiency code, which usually results from eliminating the downpipe cat. It is not a miracle cure and won't get rid of a CEL from anything else.
Racerkid
May 29, 2012 06:16 PM
saab92x
Mar 16, 2009 03:16 AM
06scooby
Oct 15, 2006 10:11 AM
Chunk
Dec 25, 2005 08:54 AM
rash
May 17, 2003 12:32 PM
