higher boost w/ bov swap
Old Sep 21, 2004 | 08:34 PM
pbchief2's Avatar
Car Info: 1995 Impreza L
Question seeing higher boost w/ bov swap
I recently swaped bov's from a txs rfl to a worx ver1.2 and my boost jumped from 1.2-1.3 to 1.4-1.5 bar, I checked all the boost lines and everything looks right could it be due to the txs leaking? Oh yeah the check engine light turns off now doesnt stay on all the time. No misfires according to the codes pulled.
Old Sep 21, 2004 | 11:04 PM
RussB's Avatar
Car Info: $200,000 sports car
sounds likely that the txs was leaking. what code was your CEL that you were getting? do you have DD or any way to log your car at the higher boost? I've got DD if you want to see how it's doing sometime. PM if you want.
Old Sep 22, 2004 | 01:11 AM
Almost certainly your old BOV was venting due to soft spring. Was it recirc or venting? If it was venting, you were running very rich most of the time, which causes misfires. The air/fuel mixture gets so dense that the electrical resistance can get higher than the ignition can overcome.
PacificLegacy
Aug 26, 2014 09:54 PM
0260B4U
Feb 6, 2004 06:12 PM
joltdudeuc
14
Mar 25, 2003 05:14 PM
blackwagonrx
Mar 1, 2003 01:41 AM
cwingo
Feb 21, 2003 06:47 PM
