Hesitations w/stock
Old Feb 19, 2003 | 09:36 PM
jimr's Avatar
Car Info: 2002 WRX Sedan
same issues
My car exhibits same stutter or hesitation under high-load, part throttle conditions, mostly under 3K or so. Once boost comes in it is smooth to redline.
I have tried injector cleaner and made little difference.
I wonder if the ECu is picking up trace detonation under wider throttle openings/boost/high-load situations and is pulling some timing back? Or is it a lean situation. I feel that if I consult the dealer they will just fall back on the "that's just normal, nuthin' we can do about it" reply like the clutch chatter.
I have tried resetting ECU, hesitation still evident. I will try the quick re-learning process this weekend.
secretaznboy
Jan 28, 2007 01:26 PM
ElJefe
Mar 5, 2005 11:39 AM
scarletrex
Jan 12, 2005 01:25 PM
mrquick68
41
Feb 12, 2004 05:57 AM
